Go to Post Your wheels look delicious. - Alexa Stott [more]
Unread 18-01-2016, 21:02
christheman200's Avatar
christheman200 christheman200 is offline
Chris Lansdale, Programmer
AKA: Chris Lansdale
FRC #0854 (Iron Bears)
christheman200 is an unknown quantity at this point
Unable to invert motor
Hi all!
I have the following code in my main robot class, and it is giving me a number of exceptions which I can't conquer:
MainDrive.setInvertedMotor(Talon.kRearLeft, true);
	MainDrive.setInvertedMotor(Talon.kRearRight, true);
Exceptions:
First line:
- Syntax error on tokens, delete these tokens
- Syntax error on token "(", < expected
Second line:
- Syntax error on tokens, TypeArgument1 expected instead
- Syntax error on token "(", , expected
Any and all help is appreciated!
Thanks, Chris
Unread 18-01-2016, 21:16
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Unable to invert motor
The errors themselves make no sense but theres some issues
  1. Why is MainDrive capitalized? variables should be lowerCamelCase
  2. You mean RobotDrive.MotorType.kRearLeft, not Talon.
There may be other syntax errors in the code as well.. post the entire file
Unread 18-01-2016, 22:55
Tparbotmail Tparbotmail is offline
FRC #3944
Tparbotmail is an unknown quantity at this point
robotDrive.setInvertedMotor(RobotDrive.MotorType.k FrontRight, true);
Unread 19-01-2016, 07:26
AKA: Chris Lansdale
Here's the rest of the code. I've tried the fixes mentioned above, but they haven't seemed to help.
package org.usfirst.frc.team854.robot;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Talon;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class Robot extends IterativeRobot {
	Joystick driveStick1 = new Joystick(1);
	Joystick driveStick2 = new Joystick(2);
	RobotDrive MainDrive = new RobotDrive(0,1);
	Talon lifter = new Talon(3);
	float lifterSpeed = 1.0f; //f for float (to have decimals!)
     * This function is run when the robot is first started up and should be
     * used for any initialization code.
    public void robotInit() {
     * This function is called periodically during autonomous
    public void autonomousPeriodic() {
     * This function is called periodically during operator control
    public void teleopPeriodic() {
        MainDrive.tankDrive(driveStick1, driveStick2);
        if(driveStick2.getRawButton(3))
        	lifter.set(lifterSpeed);
        else if(driveStick2.getRawButton(5))
        	lifter.set(-lifterSpeed);
        else
        	lifter.set(0.0);
     * This function is called periodically during test mode
    public void testPeriodic() {
Unread 19-01-2016, 08:51
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
you put it inside of the class declaration.
Move those calls to robotInit()
You can only declare functions and variables in that space you put the two calls, you can't do anything else like call functions
Unread 19-01-2016, 09:45
electronicsdude's Avatar
electronicsdude electronicsdude is offline
AKA: Spencer
FRC #4918 (The Roboctopi)
electronicsdude will become famous soon enoughelectronicsdude will become famous soon enough
Originally Posted by christheman200 View Post
Hi all!
Exceptions:
First line:
Second line:
Thanks, Chris
Just flip the polarity on the motor side of your motor controller. its legal as long as you label it and it works like a dream.
Unread 19-01-2016, 11:40
AKA: Chris Lansdale
Thanks guys!
I managed to work it out through trial and error, but thanks for clearing up why it works.
Chris
Unread 23-01-2016, 19:43
JacobD's Avatar
JacobD JacobD is offline
AKA: Jacob
FRC #1672 (Mahwah Robo T-Birds)
JacobD is an unknown quantity at this point
For future reference, I believe there is a method to invert your speed controller.
In the class SpeedController:
SpeedController.setInverted();
Correct me if I'm wrong.
SolidWorks CAD
AutoCAD
Java
Unread 24-01-2016, 17:41
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
You can't invert object within RobotDrive unless they are fed to robot drive which is a bit of work
