Go to Post I think I just found a way to replace our entire robot drive team! (no big deal, they are graduating anyway!) :D - dlavery [more]
Unread 19-01-2016, 09:17
Jonathan L. Jonathan L. is offline
FRC #1094
Jonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the rough
pic: What's weird with this image
Unread 19-01-2016, 09:20
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Re: pic: What's weird with this image
Talon SR's are Y-cabled and yet are being driven in reverse of each other... some how?
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 19-01-2016, 09:37
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Looks like someone's been playing with the calibration on those Talon SRs and managed to calibrate one backwards. I don't see a method to get back to default calibration, so you're probably stuck with just re-calibrating them
Unread 19-01-2016, 09:45
FRC #1094
We tried recalibrating, although we need to try again since I'm not sure they flashed green afterwords. Anyway, we have motors connected to each talon and both motors turned in the same direction. It must be that the internal electronics of one of the talons are reversed at the LED.
Hgree56's Avatar
Hgree56 Hgree56 is offline
AKA: Hunter Greene
FRC #4272 (Maverick Boiler Robotics)
Hgree56 will become famous soon enough
The one connector is a different shade of yellow.
2016 Indiana Tipp. District Industrial Safety Award winner
2016 Indiana Perry M. District QF w/ (3487 & 4580)
2015 Indiana Purdue District Chairman's Award winner
2015 Indiana Indianapolis District QF w/ (5403 & 4008) and Industrial Safety award winner
2015 Indiana Indianapolis, Purdue, and State Champs Industrial Safety Award Winner
2014 Crossroad GP Award Winner
2014 Boilermaker SF w/ (337 & 4213)
Unread 19-01-2016, 11:25
Shrub's Avatar
Shrub Shrub is offline
no team (N/A)
Shrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant future
The zipties aren't clipped!
Unread 19-01-2016, 12:00
Rebel888's Avatar
Rebel888 Rebel888 is offline
Treasurer
FRC #5730
Rookie Year: 2016
Rebel888 is an unknown quantity at this point
I would answer but I have literally no clue what is going on, more or less know what's wrong
Unread 19-01-2016, 12:16
That's a more remote possibility, but possibly true. Unless you have the exact same motors wired the exact same way, they might still turn differently. If a multimeter reads the same voltage when you put the red probe on M+ and the black probe on M-, then I would definitely agree with your assessment.
If it is bad internal LED wiring and the Talon is new, I would talk with Vex, Andymark, Cross the Road, or FIRST about getting a replacement. That LED is valuable for troubleshooting, and if all the fault codes are in flashing green, that's going to be extremely confusing.
Unread 19-01-2016, 13:44
JPBlacksmiths's Avatar
JPBlacksmiths JPBlacksmiths is offline
AKA: John Cashman
FRC #0806 (Brooklyn Blacksmiths)
JPBlacksmiths is a jewel in the roughJPBlacksmiths is a jewel in the roughJPBlacksmiths is a jewel in the roughJPBlacksmiths is a jewel in the rough
I would check your PWMs and make sure both are inserted the correct way
Unread 19-01-2016, 14:04
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
But a PWM is signal power ground. It shouldn't work if it is plugged in backwards.
461 Westside Boiler Invasion
45 Technokats
Unread 19-01-2016, 14:22
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Be careful with shouldn'ts. We have encountered similar issues with backwards PWMs in the past.
Hi!
Unread 19-01-2016, 15:19
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
I agree this is odd.
Does the condition move if you swap the "Y" output on the motor controllers?
As in the motors do the opposite as they are doing now.
Try swapping the y cable to the one used on the other side and note if the condition follows.
Or just swap the "Y" cables on the RoboRio.
Does the condition follow the cable or stays with the motor controllers?
I would make sure when recalibrating not to use a "Y" cable.
And test each motor separately and not on the "Y cable.
If the problem still exists only when on that specific Y cable, its got issues.
This should narrow down the issue to the cable or one motor controller.
Just curious is the voltage output of those motors indeed opposite to each other.
Hope you get this sorted.
Aloha and good luck this season!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 19-01-2016, 17:12
FRC #1094
We did not check with a multimeter so that is a possibility.
We did swap the PWM cables between the talons and on the roboRIO. The problem always stuck on one of the talons (I believe the one on the right of the image).
As I said before, the direction of the motors was the same. We did not test the voltage yet, however.
Unread 20-01-2016, 11:26
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I bet one of the leds is burned out. We have a similar issue, but ours is always green on an old one. Does that one ever turn green?
Unread 20-01-2016, 11:35
FRC #1094
This is always backward of what the signal is. When we say forward, it turns red; When we say backward, it turns green.
