Go to Post Defense shall reign supreme. - Corey Balint [more]
Unread 18-01-2016, 21:24
paul.dornfeld paul.dornfeld is offline
FRC #5523
paul.dornfeld is an unknown quantity at this point
Sally Door: Swing Direction
Will the Sally Door (as viewed from a bot in the the neutral zone) be swinging from the left (i.e. hinged on the left side), right, or might it change for each different event or location? Thank you.
Unread 18-01-2016, 21:26
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Sally Door: Swing Direction
Hinges on Left so opens Left when facing it from neutral (won't change)
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 18-01-2016, 21:33
FRC #5523
Thank you for the quick reply. I guess I should have clarified that I am looking for some official documentation that confirms that it does, in fact, open with the hinges always on the left. I have searched both here and Q & A and have found no "official" word supporting this and this is a critical feature of our plan. It would be sad to find out competition day that it swung from the side that we did not plan for.
Unread 18-01-2016, 21:40
All drawings and videos show the same. 99.999% sure its that way.
Unread 19-01-2016, 06:05
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If the Sally Port would be installed so that the hinge is on the right, it would open into the courtyard rather than the neutral zone. That should constitute a field fault. It would also be defeatable with a drive system only.
Unread 19-01-2016, 09:35
FRC #5523
Yes, that is true of a left-hinged door installed backwards, but my question involves the actual construction: is there anything that mandates that the door be constructed as a left-hinged door or might we encounter either sided hinge in the competition?
Unread 19-01-2016, 09:41
BoilerMentor BoilerMentor is offline
FRC #1747
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
The way that the outer works base and defense pieces interact it isn't physically possible to install them oriented incorrectly. The defenses are on casters that roll down ramps in the outer works base to seat them in place. The casters are in a trapezoidal pattern on the bottom of the defense. Because the spacing of the casters differs front to back it provides orientation in conjunction with the position of the ramps and slots for the casters in the outer works base.
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
2015-Present Ri3D Team Indiana - Mechanical and Fabrication
Unread 19-01-2016, 11:29
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Viewing the Sally Port from the direction that it opens into, the hinge must be on the left. This is mandated by the field drawings. It is also mandated by the Game Manual that the Sally Port must open into the Neutral Zone. So combining these two mandates, we get the fact that the hinge must be on the left if viewed from the Neutral Zone. If the above assumptions are correct (and I believe they are), then that is the official word you are looking for.
Unread 19-01-2016, 11:34
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
https://firstfrc.blob.core.windows.n...Components.pdf
Page 71 shows assembly.
Unread 19-01-2016, 17:44
GaryVoshol's Avatar
Cogito ergo arbitro
You mean other than the field construction documents posted on the website here? http://www.firstinspires.org/resourc...nual-qa-system
I haven't felt the need to check, but I'm sure if you peruse them you will find that it shows which side the hinge is on.
(since 2004)
Unread 20-01-2016, 00:47
FRC #5523
Thank you, We will go with that.
FRC #5523
That is a great resource. Thank you for pointing it out.
Unread 20-01-2016, 00:48
FRC #5523
Originally Posted by TheOtherGuy View Post
Yes, I see what you mean. Thank you.
Unread 20-01-2016, 02:03
Monochron's Avatar
Engineering Mentor
View Post
Just to be clear though, the videos are not authoritative, only the manuals and Q&A are. Following what I said above abides by this and leads you to the same result.
Unread 20-01-2016, 10:19
FRC #5523
Understood. We don't have the resources to build our own test field, so hadn't yet had occasion to look at the field manual. The field manual makes it appear unambiguous and straightforward. Very helpful. Thanks again.
