Go to Post work? I can't remember when the last time i did that was... - Carolyn Duncan [more]
Unread 19-01-2016, 10:03
Whippet's Avatar
Whippet Whippet is online now
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: Bumper requirement.
Originally Posted by matthewdenny View Post
Technically isn't the 8" measures from the corner of the robot, not the corner of the bumpers? This would require it to extend an additional ~3.25" in to the gap on each side.
This is correct. I should have clarified that in the drawing, but that is why the arrows didn't extend all the way to the end of the bumper.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 19-01-2016, 12:15
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
R26 then states BUMPERS must be supported by the structure/frame of the ROBOT
This would mean the front C-channel must extend in from the corner >=8" correct?
How much of the vertical 5" bumper backup board must be supported by the structure/frame?
Unread 19-01-2016, 12:47
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
There are many ways to support it, but the simple version is to have the channel be 8" long. There is no specific amount in the vertical direction that needs to be supported. The main point of the rule is that you can't have the end of the bumper floating in free space. A flat sheet of thin metal that covers the entire back of the bumper also wouldn't count as supported for most inspectors.
My guideline is that if the bumper was not present, you wouldn't be able to bend the frame behind it easily by hand. If you are counting on the bumper to be a structural element of your frame, then it won't pass inspection.
Unread 19-01-2016, 14:18
Rookie Year: 2015
No we would cut the regular c-channel to 8". Seems though we might only have the bottom 1 to 2" in contact with the frame. We will see, just wanted to know if there was a rule we had to pay attention to.
Thanks you all been a huge help
