Go to Post The kick-off is your opportunity to finally open the REALLY BIG box that has been sitting under the tree. - dlavery [more]
Unread 19-01-2016, 09:42
natejo99's Avatar
natejo99 natejo99 is offline
Captain/Human Player
AKA: Nate Johansen
FRC #0074 (Team C.H.A.O.S.)
natejo99 is on a distinguished road
Velcro for electrical components
We are looking to use velcro to secure all of our electrical components to our drive base. This would help to increase accesiblity, and to make it easier to replace components. However, with all the difficult terrain this year, there might be an issue with components being knocked loose. Which method would be more effective?
2013-Present - Student, FRC 74
2014 FRC Champions - 254, 469, 2848, 74
2014 FRC MSC Finalists - 1718, 67, 74
2016 Traverse City District Winners - 3688, 74, 6128
2016 Tesla Quarterfinalists - 74, 2054, 4468, 3238
Thanks to our 2016 Alliance Partners:
4580, 71, 2405, 3572, 3688, 6128, 5505, 2054, 4468, 3238
Unread 19-01-2016, 10:05
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Re: Velcro for electrical components
Try zip ties...quick removal and installation.
"A genius is just a talented person who does his homework" T. Edison
Unread 19-01-2016, 10:07
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Don't use Velcro, use this instead:
http://www.mcmaster.com/#mushroom-he...eners/=10r0kpf
It also goes by the brand name 'Dual Lock'.
It has the advantage of not being 'sided' (there's no hook and loop, it's all the same thing), and it also snaps together, not at all like Velcro's mushy connection. We use it on most of our electrical components. It's expensive, but great stuff.
That said, with the rough terrain you might want some suspenders to go with your belts.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 19-01-2016, 10:11
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Velcro works just fine. We've used it for many years.
If you are very concerned then zipties work well too.
If you have the weight and want to go to the extreme then use bolts.
Unread 19-01-2016, 10:17
philso philso is offline
FRC #2587
Try attaching some (old) components on a sample panel and beat the panel on something to see if they come loose. We used Velcro to attach all the electrical components (PDP, Talons, Spike, VR) on our electronics panels for Aerial Assault and nothing came loose.
You may also want to try using the heavy duty 3M/Scotch DuoLock. I find that the 10 lb. rated stuff holds better and is not as "squishy" as the Velcro is so the mounted item does not rock slightly as when attached with Velcro. It also only has one type (not hook and loop) so it is not possible to screw up and install hook opposite hook and loop opposite loop. It is on the racks next to the big rolls of Velcro at Home Depot.
Scotch-1-in-x-4-ft-Black-Extreme-Fasteners-RF6741/205520125
Scotch-1-in-x-4-ft-Clear-Extreme-Fasteners-RF6740/205520112
Scotch-1-in-x-10-ft-Black-Extreme-Fasteners-RF6761/204465400
Scotch-1-in-x-10-ft-Clear-Extreme-Fasteners-RF6760/204465393
Unread 19-01-2016, 10:46
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
Belt and suspenders in one would be waxed lace cord:
http://www.specialized.net/Specializ...pool-4862.aspx
A good tutorial from this site will get you going:
http://www.aeroelectric.com/articles...able_lace.html
Watch a few Youtube videos on cable lacing to get the technique down and it will NEVER come undone without cutting it apart. As you tighten, the friction melts a little of the wax which solidifies in the knot, keeping it in place so that you can cut the free ends 1/4" away without worry of them pulling back through. As a bonus, you don't have the sharp edges that come with zip ties that are improperly cut and it just looks awesome when implemented. I would do it as a final dressing up of the wiring once no changes are to be done as it does take some time, but well worth it in my opinion.
This image shows the Mars Hand Lens Imager (MAHLI) on NASA's Curiosity rover with all of the wiring stitched up using waxed lace.
http://www.nasa.gov/centers/jpl/imag...ia16161-43.jpg
Anyone planning on going into the telecommunication industry dealing with equipment installation directly, particularly sites (POPs, COs, even self-respecting wiring closets), will become very familiar with the "No Zip Ties/Tie Wraps Allowed!" Waxed Lace, or much less frequently if not permanent Velcro/Hook & Loop/Dual Lock, is all that is allowed. I've sometimes stood there and marveled at the lacing skills of some of the cabling installations that were 80+ years old and how beautiful they look and then trying to live up to the same standards in my new cabling for modern gear. We've even left some of the old stuff in place just to show how it should be done.
Nate
edong4273's Avatar
edong4273 edong4273 is offline
Team 2375's Very Own Dong
AKA: Edmund "Dong" Dong
FRC #2375 (Dragon Robotics)
Rookie Year: 2015
edong4273 is on a distinguished road
As JCharlton has said, I do believe that our team normally uses Duel Lock along with zip ties to keep our electronics down and to keep out wires clean.
Unread 19-01-2016, 10:57
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We usually use wood screws....since Velcro doesn't stick well to wood, and zip ties are kind of difficult to use in blind holes....
Unread 19-01-2016, 12:47
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
Same here, although we've been known to use a couple of zipties for heavier and more "in the way" components. I do not recommend "fuzzy" Velcro for mounting electronics.
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 19-01-2016, 12:53
pfreivald's Avatar
AKA: Patrick Freivald
We've used "industrial strength" hook-and-loop (Velcro) for mounting all of our pneumatics since at least 2010 and never had a single issue. Why wouldn't you recommend it?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 19-01-2016, 13:20
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We personally stick to zip ties except on the radio where we use Duralock.
Unread 19-01-2016, 16:31
Philip Arola's Avatar
Philip Arola Philip Arola is offline
You can check out any time you like
AKA: KG7VAM
FRC #1510 (Wildcats), FRC #2898 (The Flying Hedgehogs)
Philip Arola is an unknown quantity at this point
As far as I can recall, we have bolted down nearly all our electronics, with the exception of last minute gadgets.
If you cannot drill into the surface, VHB is one of the most annoyingly powerful adhesives I've ever had the pleasure of using. Which, coincidentally, is included in the KoP this year.
Unread 19-01-2016, 16:51
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Nice, we've used this stuff before but our mentor that got it for us left the team a few years back and we never figured out where to get it. Guess I should have figured McMaster would have it.
A word of warning to teams considering it for the first time though: Be careful when using "Industrial strength" variants of dual lock, in our experience, the lock is so strong that the adhesive fails before the lock does. We've actually resorted to using crowbars to remove electrical components that were secured this way in the past.
Unread 19-01-2016, 17:14
juchong's Avatar
Electrical Engineer
AKA: Juan Chong
From what I've observed, the cheap, "fuzzy" Velcro keeps things from falling off, but doesn't keep them from moving/flexing. Since robots are expected to go over bumps and traverse rough terrain this year, I would worry about the Velcro failing and a connector coming in contact with the robot frame.
In addition, the more electrical components are allowed to move/shake, the more likely they are to disconnect. Added strain on wires and connectors can make a bad crimp fail or a spring-loaded connector release a wire.
If I were inspecting robots, I would not pass anyone who used only "fuzzy" Velcro to attach their electronics. If "industrial" Velcro was used, I would spot check the components and make sure that nothing was in danger of failure.
Unread 19-01-2016, 18:45
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Other places have this stuff way cheaper than McMaster (Amazon is your friend). I've found that the 10lb stuff is pretty good at keeping routers and switches on walls. When I first started, I bought the industrial stuff. The first time I removed the equipment with a sharp tug, I pulled the wallboard off. Granted it was badly installed with only three screws ....
On the other hand, the adhesive comes in temp ranges. So if you are putting it on something that may get hot, you might want to look at things other than the 110F degree versions.
3M Dual Lock site with different part numbers
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
