Go to Post It is better to err on the side of caution than to put yourself in a position to have a referee or judge make a call against you. Build smart! - Sean Schuff [more]
Unread 17-01-2016, 16:11
Team DRIFT Team DRIFT is offline
FRC #4091
Team DRIFT is an unknown quantity at this point
How to use GRIP?
How do you get the image of the camera into GRIP? and also, how do you get the results from that into the network table? Do you use GRIP outside of your code? or do you have to incorporate it into it?
Unread 17-01-2016, 16:18
timtim17's Avatar
timtim17 timtim17 is offline
Programmer
AKA: Austin
FRC #1294 (Top Gun Robotics)
timtim17 has a spectacular aura abouttimtim17 has a spectacular aura abouttimtim17 has a spectacular aura about
Re: How to use GRIP?
As far as I know, you run GRIP on either your DS PC, your roboRIO, or a secondary processor such as a Raspberry Pi. The webcam is fed in as just a normal webcam ("Add Webcam"), and the data can be fed out to NetworkTables using a block in GRIP (i.e. Publish ContoursReport). See this example from WPILib screensteps to see how to use the data in your robot code.
Unread 17-01-2016, 16:19
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
Put the Web cam on your PC and walk through the examples found http://wpilib.screenstepslive.com/s/4485/m/50711
Once you see the power of the tool then you will need to learn how to deploy the app to the roboRio. First the tutorials on using grip.
Unread 17-01-2016, 17:56
FRC #4091
Thanks for the help, timtim17 and cpapplefamily.
We are already aware of the Screensteps and we love them and we have seen the power of GRIP (it's pretty freaking powerful, I must admit). But how do we actually deploy it to the roboRIO?
Also, timtim17, our webcam is connected to our roboRIO, not our computer, so we can't actually add it in the "add a webcam" option. Is there a way to add it on there through the roboRIO?
The other thing is that I'm not sure how to actually connect the resulting data to the code. I know that there is a deploy option, where You type in Your team number or roboRIO's address but it isn't working for us, and I'm not certain as to why. With that in mind, I don't see how it could publish to the tables without even knowing where the tables it's publishing to are.
Does anyone know about running it on a separate processor, on the DS or the roboRIO and how to actually do any of those? All help is appreciated.
As I'm sure is clear, we're fairly confused. Thanks for all the help!
Unread 17-01-2016, 18:04
FRC #4091
Timtim17, I just found the link You give to someone else with a similar question. I think that will likely help us in any way we need. We'll let You know how it works out tomorrow.
Once more, thanks.
Unread 17-01-2016, 19:25
Rookie Year: 2015
The deploy to Rio has been the hurdle. As far as I know you must create the profile.grip with the camera connected to the pc. Then get over the hurdle of deploing. There has been lots of chatter on how to get this to work. I been previewing the latest repository and the next release will be the one that takes this app off the map. I hadn't tested to see if the deploy function has improved let's hope.
Unread 18-01-2016, 02:37
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Yeah, the deploy UI seems to be tripping up a lot of people from what I can tell. I've been working on a new version that has better error reporting and status messages, among other reliability improvements.
https://github.com/WPIRoboticsProjects/GRIP/pull/386
Feedback would be very much appreciated.
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
Unread 19-01-2016, 01:08
FRC #4091
Thanks, guys. At least it's good to know that we're not alone in our struggle If/when You have some way of getting past the whole deploying issue, please let us know.
Much appreciated.
Unread 19-01-2016, 10:03
Xanawatt Xanawatt is offline
FRC #1024
Xanawatt is an unknown quantity at this point
If I wanted to run GRIP on a raspberry pi, would I have to download the linux version of GRIP? I currently have the pi running raspbian but that can be changed if need be.
Unread 19-01-2016, 10:25
iSpotix iSpotix is offline
FRC #4049
iSpotix is an unknown quantity at this point
Yes, from the raspbian website.
Raspbian is a free operating system based on Debian optimized for the Raspberry Pi hardware.
So you will want to download the linux version.
Unread 19-01-2016, 12:51
FRC #0237
The official release of GRIP doesn't support Raspberry Pi yet. The linux version in the downloads is for x64 processors, and the deployable roboRIO binaries are for the arm-softfp ABI (the raspberry pi is arm-hardfp)
Someone
did manage to get a version built for the Pi, though. I haven't personally tested it, but it looks promising.
https://www.dropbox.com/s/7iueslu26a...yable.jar?dl=0
Unread 20-01-2016, 15:31
FRC #4091
This is the error I get, if that helps:
Failed to deploy
java.io.IOException: Failed to deploy
at edu.wpi.grip.ui.util.deployment.DeployedInstanceMa nager.scpFileToTarget(DeployedInstanceManager.java :162)
at edu.wpi.grip.ui.util.deployment.DeployedInstanceMa nager.access$200(DeployedInstanceManager.java:41)
at edu.wpi.grip.ui.util.deployment.DeployedInstanceMa nager$1.call(DeployedInstanceManager.java:141)
at edu.wpi.grip.ui.util.deployment.DeployedInstanceMa nager$1.call(DeployedInstanceManager.java:137)
at java.util.concurrent.FutureTask.run(FutureTask.jav a:266)
at java.util.concurrent.Executors$RunnableAdapter.cal l(Executors.java:511)
at java.util.concurrent.ThreadPoolExecutor.runWorker( ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run (ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: com.jcraft.jsch.JSchException: Auth fail
at org.apache.tools.ant.taskdefs.optional.ssh.Scp.exe cute(Scp.java:245)
at edu.wpi.grip.ui.util.deployment.DeployedInstanceMa nager.scpFileToTarget(DeployedInstanceManager.java :160)
... 9 more
at com.jcraft.jsch.Session.connect(Session.java:512)
at com.jcraft.jsch.Session.connect(Session.java:183)
at org.apache.tools.ant.taskdefs.optional.ssh.SSHBase .openSession(SSHBase.java:223)
at org.apache.tools.ant.taskdefs.optional.ssh.Scp.upl oad(Scp.java:324)
at org.apache.tools.ant.taskdefs.optional.ssh.Scp.exe cute(Scp.java:226)
... 10 more
Unread 20-01-2016, 15:40
AlexanderTheOK AlexanderTheOK is offline
Guy
AlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really nice
I noticed that in terms of deployment, GRIP can only be "deployed" to the RoboRIO.
With that in mind, as far as I can tell, the only way to run it during a match on the driver station would be to use the application itself with all of the editor tools still visible. Is there a way to change some settings to get a minimal UI in GRIP on Windows? I feel like the screen real estate this takes up might just be a bit too large for some smaller driver station laptops.
Unread 20-01-2016, 20:52
MikePerreman's Avatar
MikePerreman MikePerreman is offline
FRC #0247
MikePerreman is an unknown quantity at this point
is there a way to intercept the live feed on the SmartDashboard and use that as an input for grip?
Unread 21-01-2016, 01:19
FRC #0237
Not currently, no.
GRIP v1.1.0 will have a few improvements that might help with these - one is a "Publish Video" operation that will let you run GRIP in headless mode but still see video in SmartDashboard. This only works if GRIP is running on the roboRIO, though (SmartDashboard is hardcoded to get video from the roboRIO's address. I'll see if I can submit a patch to change this.)
Another is a rewritten deploy tool that lets you specify custom addresses, usernames, directories, etc. Although, if you're talking about running GRIP in headless mode on your laptop, you can already do that by running the JAR in AppData\GRIP\app\core-1.0.0-all.jar from the command line. If there's more of a demand for this sort of setup, we could create a wiki page describing it.
