Go to Post If people are getting offended at seeing other teams list their accomplishments, maybe they should spend less time whining and more time doing things to make their own team win. - artdutra04 [more]
  #31   Spotlight this post!
Unread 19-01-2016, 10:37
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Motor Used for Shooting
We're using 775Pro's through a Versaplanetary, geared to appropriate reductions for the wheel size (still not determined). Other than power:weight as has been stated, I like the open air cooling that's perfect for a high duty cycle use case like what a shooting wheel does. For shooters that use low compression on the ball, it's perfect.
GitHub
  #32   Spotlight this post!
Unread 19-01-2016, 11:32
Originally Posted by Nick.kremer View Post
I have seen you posting the same thing in a few other threads. I was wondering if you have a minute to explain/have a link to a thread that explains how operating voltage is tied to using control loops, to someone who knows very little about such things?
What Gus said:
Originally Posted by GeeTwo View Post
The control works by varying the voltage supplied to the motor. The motor controllers cannot put out a higher voltage than they take in from the battery. Without getting into PID theory, essentially if it's going too slow, the voltage is increased; if it's going too fast, the voltage is decreased. If you're running the motor at top speed (giving it full voltage), you can only adjust down. Far better to have your nominal operating speed at say 75% of top speed, especially later in the match when the battery voltage is reduced.
If you still have questions, please do ask.
  #33   Spotlight this post!
Unread 19-01-2016, 16:36
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Reading between the lines, it sounds like you are not planning to control wheel speed, is that right?
Since the target is a hole in the wall and not a hoop. I think getting your shooter to have a fairly straight trajectory is needed. Let the motor rip and throw a fastball into the hole. It's all about aiming.
Roy
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
  #34   Spotlight this post!
Unread 19-01-2016, 16:39
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Roy
So what's your plan if your battery runs low, or (hopefully not) you forget to switch it between rounds? Pray that it still makes it?
Academic Student (Forever)
  #35   Spotlight this post!
Unread 19-01-2016, 16:43
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
"Letting the motor rip" could still mean controlling for voltage fluctuations. Just gear your shooter such that at 80%-85% speed you're still shooting much harder than you need to.
  #36   Spotlight this post!
Unread 19-01-2016, 16:52
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
We have have exceptional results with our prototype using a single RS 775-18 geared 2:1 driving a pair of 4" wheels. We run the motor anywhere between 8.5v and 10v.
Our intent is to run a pair of 775pro's geared 3:1 (60:19 to be exact) and (This is for you, Ether) Bang-Bang to control the rate of the wheel.
Our plan is to use a single retro reflective section and just measure the period to determine the rate the wheel is spinning. We may end up with two sections to preserve balance in the wheel.
  #37   Spotlight this post!
Unread 19-01-2016, 17:02
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Originally Posted by Mike Schreiber View Post
For a shooter it really doesn't matter too much. The main thing that matters is your RPM and compression, I'm not convinced torque has a large impact on the shot as much as it has on spin up time / slow down after a ball is shot (which doesn't matter in this game). You want to get the wheels going at a specific repeatable speed to get an accurate shot - generally between 3000-8000 RPM with a 4" wheel(s) and depending on the distance / angle etc.
The advantage to a Mini CIM is that you can direct drive and be at around the right RPM, the disadvantage is that you can't really go any faster than free speed unless you gear up - which is silly. The Bag, 775, or 550 all have high free speeds and require some gearing down, but a versa planetary box makes that really easy. 550s are a little weird this year since you can't get them from VP or AM. Also consider packaging and where your motor / shooter will live inside the robot.
Cool Thanks!
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
  #38   Spotlight this post!
Unread 19-01-2016, 22:08
lark95's Avatar
lark95 lark95 is offline
Red Ranger
AKA: Joe L.
FRC #3418 (RoboRiot)
Team Role: Driver
lark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of light
We have plenty left over from previous years so it is not a problem for us. However you can order the 550's directly from banebots.
We have done some more testing of the 550's on a 3:1 with 4 in wheels and are able to get a very straight shot at full speed.
FRC Rebound Rumble | Ultimate Ascent | Aerial Assist | Recycle Rush | FIRST Stronghold | FIRST STEAMWORKS
FLL Senior Solutions | Nature's Fury | Trash Treck | Animal Allies
  #39   Spotlight this post!
Unread 19-01-2016, 22:23
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Originally Posted by popnbrown View Post
We're also looking at using a 775pro at a 3:1 but I'm having trouble figuring out how to attach a longer shaft to the VersaPlanetary Gearbox shaft.
Try http://www.vexrobotics.com/vexpro/motion/217-4008.html
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
  #40   Spotlight this post!
Unread 20-01-2016, 10:59
triumph69's Avatar
triumph69 triumph69 is offline
triumph69 is an unknown quantity at this point
I figure in order to gain efficiency it would be better to drive the shooter wheels directly from the gearbox, without adding a second set of gears, belt/pulley or sprocket/chain set-up. We don't have a lathe, so is our only option to not directly drive the shooter wheel?
Vex Pro has the solution. Hex shaft coupler.
http://www.vexrobotics.com/217-4008.html
  #41   Spotlight this post!
Unread 20-01-2016, 11:54
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
We are using a miniCIM to power a ratcheting shift-to-freefall gearbox.
It isn't shiny enough.
  #42   Spotlight this post!
Unread 20-01-2016, 12:56
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Can you describe your reasoning for this? What is the pupose of a ratchet on your shooter? And why the need to shift to neutral?
  #43   Spotlight this post!
Unread 20-01-2016, 13:07
CalTran's Avatar
Missouri S&T Senior
Catapult?
  #44   Spotlight this post!
Unread 20-01-2016, 18:19
Catapult?
Close, spring-powered linear puncher.
  #45   Spotlight this post!
Unread 20-01-2016, 19:46
billbo911's Avatar
Shades of 971 in 2014!
