Go to Post [on the 2007 field control software] its crazy -- not only did they sound like the same old sound effects we know and love, but it seemed like they actually occured at the time they were supposed to! :) - Aidan F. Browne [more]
Unread 19-01-2016, 17:50
Landonh12's Avatar
Landonh12 Landonh12 is offline
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
Re: Robot Scan Time
What language are you using? In LabVIEW you can set custom loop times, and in Java/C++ the loop interval for the scheduler is defaulted to 20ms (noted here: https://wpilib.screenstepslive.com/s...d-programming).
Team Fusion 364 - Driver/Programmer 2012-2015; Controls Mentor 2016-Present
Unread 19-01-2016, 17:51
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
Re: Robot Scan Time
Note that he is referring to code written in Periodic Tasks, code written in Teleop will be executed only when a packet from the driver station is received.
Ri3D - 'Snow Problem Programmer
FRC 2169 Alumni
Unread 19-01-2016, 17:56
FancyGerald FancyGerald is offline
FRC #3098
FancyGerald is an unknown quantity at this point
Re: Robot Scan Time
We are using java to program our robot and we would like to know the scan time if the scan time were ever to fluctuate.
Unread 19-01-2016, 17:59
Landonh12's Avatar
270 points
AKA: Landon Haugh
Re: Robot Scan Time
It shouldn't fluctuate unless you start dropping packets and experience sporadic ping timings. What are you going to use this information for?
Unread 19-01-2016, 18:07
FRC #3098
Re: Robot Scan Time
We want to have acceleration for our drive train.
My idea was to increase the speed of a motor at a constant rate multiplied by the scan time of the robot.
if(maxSpeed > currentSpeed)
    currentSpeed += ACCELERATION * SCANTIME;
Unread 19-01-2016, 19:28
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: Robot Scan Time
The time elapsed is going to be approximately 20ms, but it will fluctuate depending on network latencies.
Just perform the calculation each time through the loop.
currentTime = Timer.getFPGATimestamp(); //time in seconds
elapsedTime = currentTime - lastTime;
//do your math
lastTime = currentTime;
More info on what the getFPGATimestamp method does here: http://team2168.org/javadoc/edu/wpi/...PGATimestamp--
http://team2168.org
Unread 19-01-2016, 20:05
mynameistoe mynameistoe is offline
FRC #3098
mynameistoe is an unknown quantity at this point
Re: Robot Scan Time
Thank you all for your help!
-3098
