Go to Post If you want to make change, you have to know what you're trying to change. - [more]
Unread 19-01-2016, 19:22
daniel.schwartz daniel.schwartz is offline
FRC #5099
daniel.schwartz is an unknown quantity at this point
Fitting in the batter to scale?
Just wondering if you need to fit in the batter in order to scale the tower.
Unread 19-01-2016, 19:37
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Fitting in the batter to scale?
Did you find the definition of SCALE in the manual? If so, does it say anything about the BATTER?
(Teaching a man to fish here, rather than giving him a fish.)
(since 2004)
Unread 19-01-2016, 19:47
FRC #5099
I may have phrased it wrong, when you have your whole team surrounding the tower ready to scale. Do you have to fully be on the batter ramp around the tower, or can u hang off a little?
Unread 19-01-2016, 20:35
RoboChair's Avatar
AKA: Devin Castellucci
You are correct in assuming that fitting 3 robots with bumpers on the batter and scaling is a spacing problem. The tower faces are only about 28" wide and you are required to have about 6-7 inches of bumper width outside your robot frame. This means that if you wanted to fit within the 28" size of the tower face you can only make your robot about 21" wide plus 7" of bumper. You can however scale the tower to a higher level then what the rules require in order to clear the low goal even more, giving your alliance members more room to scale. Or you could push yourself away from the wall to accomplish the same effect.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 19-01-2016, 23:03
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Not from a direct rules standpoint, but perhaps from a practical standpoint. If you can't get at least part of your robot in the batter, it would be difficult (though not impossible if you can tilt toward the tower) to pull up on a rung without going outside of the 15" extension limit on the frame perimeter. The only load-bearing surfaces of the tower are the batter and the rung.
