Go to Post God bless the camera. That's all I gotta say. - Bharat Nain [more]
Unread 19-01-2016, 18:43
jmb888 jmb888 is offline
AKA: Justin Beekman
FRC #0280 (TnT)
Rookie Year: 2015
jmb888 is an unknown quantity at this point
Re: Aiming with Vision
I'm having trouble developing the vision detecting code connecting with the vision assistant vi. Do you mind posting a picture of yours?
Unread 19-01-2016, 19:32
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
Check out the 2012 vision whitepaper and roborealm tutorial. That's pretty much where I got my algorithm from.
2015 MAR District Champions
Unread 19-01-2016, 21:05
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Did you guys know about the example which comes with the FRC code? It's located in "C:\Program Files x86\National Instruments\LabView 2015\Examples\FRC\roboRIO\FRC\Vision\2016 Vision Example" There's even sample images.
Unread 22-01-2016, 19:01
AKA: Justin Beekman
FRC #0280 (TnT)
Rookie Year: 2015
Is that somewhere under the vision folder in the FRC examples you find iin LabView because I looked through there and other folders in those examples and couldn't find this specific tutorial.
Unread 22-01-2016, 19:14
The ride never ends
http://bfy.tw/3pIk
Unread 09-02-2016, 16:50
jfox100 jfox100 is offline
GameAnnouncer: Dallas,Bayou, Champs
FRC #1255 (FRC1255 - Blarglefish)
jfox100 is a name known to alljfox100 is a name known to alljfox100 is a name known to alljfox100 is a name known to alljfox100 is a name known to alljfox100 is a name known to all
Can you send me a screen shot of your Vision Assistant script that was used for your vision code? we have tried several scripts (that are similar to the white paper and that have worked in previous years, but not this year) that work great to finding a target in Vision Assistant, but when they are exported as a VI and used in labview, they dont return any matches. Any chance you could send pictures of your script?
Thanks
Unread 10-02-2016, 09:49
Similarly, I'd be interested in seeing/hearing about your scripts that you expected to work, but found that they didn't.
Did you have luck with the example code or aspects of it?
Greg McKaskle
