Go to Post Only two letters and one punctuation mark can describe my feelings about this... NNNOOOOOOOOOOO!!! :( - Qbranch [more]
Unread 19-01-2016, 18:11
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Heat/Friction of 775 + Versaplanetary
Hi all,
We've been experimenting with various motor + veraplanetary combinations for our shooter, and with the higher power 775pro, we noticed a lot of heat (presumably due to friction) being generated. It got to the point where the gearbox was too hot to hold.
We then ran the same combination through our power meter, and saw the 775 was drawing a whopping ~150W (on a ~300W motor) just to overcome the friction. We saw this consistently across two motors, and multiple gear ratios (inc 1:1)
Interestingly, with no gearbox the motor was still pulling on the order of ~30W, more than triple what the maths says it should be.
For comparison, a similar setup with a BAG motor resulted in 30W w/ gearbox no load, and 15W with nothing at all.
We'll do more experimenting tonight, we could well be just putting the versaplanetary together wrong, but what has everyone else's experience been?
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 19-01-2016, 18:23
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Heat/Friction of 775 + Versaplanetary
Need some context: What manipulator? Does the manipulator free-spin well without the gearbox attached? Is there any chatter in the gearbox when you back drive it with your hand? You greased the gearbox, right?
GitHub
Unread 19-01-2016, 18:25
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I can't comment on the 775pro yet since we just ordered them, but I do recall in 2014 we encountered a similar problem with our VP's running RS550s. It wasn't quite to that extreme, but they were very touchy with how they were assembled as to how much friction they had inherent to the gearbox. I would suggest disassembling the gearbox (or at least loosening the screws a bit) and trying it again.
Unread 19-01-2016, 18:35
President, VEX Robotics, Inc.
Originally Posted by timytamy View Post
Hi all,
How are you calculating power?
Is the 150W you are referring to the electrical power or mechanical power?
I can tell you the 340ish power that is on the VEXpro web site is at max power and is mechanical power. There is a big difference.
I assume you are referring to electrical power and, if so, you were probably pulling 12 amps from the power source if it was at 12 volts. This is definitely not normal.
We are running 5:1 VP with the 775pro and they are only pulling 2.4 amps, which is about 30ish Watts of electrical power.
I pulled all of these numbers from motors.vex.com/775pro. If you click to expand the motor curve, then all of the data is there.
Paul
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 19-01-2016, 19:26
timytamy's Avatar
AKA: Tim
No manipulator, just gearbox. We've greased on assembly of the stages (except 1:1)
We are measuring electrical power (using http://www.powerwerx.com/digital-met...owerpoles.html), under these no-load conditions we expect to see all of that converted to heat (and some sound), which is consistent with what we're seeing.
You're correct that the max power isn't really a valid comparison as we're measuring power at a completely different stage, I included it more to give a sense of the scale.
We expected to see ~30W like the BAG, and like your tests. We're unsure of what has gone wrong. We're interested in what other people's experiences have been.
Do you recall anything that can indicate the order of magnitude you experienced? No-load power (or current) measurement? Could you hold onto the motor/gearbox after running it for a little while?
Tim W
Sydney, Australia
Unread 19-01-2016, 20:23
RoboChair's Avatar
AKA: Devin Castellucci
Too much grease? You don't want too much in there if you are spinning that fast.
Wrong size planet and/or sun gear pairing?
Ring gears not lining up well or unevenly tightened?
Motor to sun gear hub mounted too far on or not on far enough?
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 19-01-2016, 22:45
MetaEngineer's Avatar
MetaEngineer MetaEngineer is offline
Director of magic smoke
AKA: Barden
FRC #0246
MetaEngineer is an unknown quantity at this point
Something is certainly wrong.
The 775pro we wired up a few days ago would pull less than 1 amp at 12 volts (<12W) unloaded. With a lightly greased 3:1 versaplanetary and a small shooter wheel, current draw was around 14 amps at 12 volts (~168W).
Wheel speed was 5340 RPM and motor speed 16020 RPM. After a few minutes of launching boulders, motor case got to maybe 38 C (~100 F) and outside of gearbox got to around 41 C (~106 F). Warm, but to be expected with the high speeds involved.
Tomorrow I could get better data on RPM and power consumption of motor + gearbox without the wheel, which wastes quite a lot of power moving air.
Unread 19-01-2016, 22:58
Bob Steele's Avatar
AKA: Bob Steele
As Evan mentioned earlier, we had heat buildup issues a few years back when we started using the Versaplanetaries. You must attach the motor using the instructions exactly as VEX recommends. The gearboxes we used were before the removed the outside bearings. When the design changed to no outside bearings (right after the shaft connects) it was much easier to align everything properly and not get so much heat.
Some of the heat is characteristic of the gearbox for some reason they always run a little hot. I would suggest you contact VEX and ask them for advice.
If you are having that much friction there must be an alignment issue.
These are great little transmissions... so easy to mount with such great flexibility to mount and a wide choice of motors. We primarily use the 775 with all of our applications.
Unread 19-01-2016, 23:07
Hawktobot Hawktobot is offline
AKA: Mike
FRC #4921 (Hawktobots)
Hawktobot is an unknown quantity at this point
Silly question. Did you lubricate the gears? Our team just assembled our 775pro and planetary as well. We noticed that the gears were partially lubricated but we added extra to be on the safe side. We have not tested the motors yet. We did notice that over torqueing the bolts when assembling affected the function.
Unread 19-01-2016, 23:26
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Overlubricating is also very bad in VersaPlanetaries. Last spring when I was working on some miniature robots for a non-FRC project, my group had to assemble 15 identical VersaPlanetaries and the the ones that have given us the most trouble are the ones that were overlubricated initially.
I'd second the advice elsewhere in this thread: make sure you don't have too much lubrication, and make sure everything is properly aligned. Given those two things, I've never had an issue with a VersaPlanetary (other than losing a few of the motor adapters ).
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 19-01-2016, 23:36
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
To confirm,
OP are you using the piloted versaplanetary plates or the metal plate?
R.C.
MadTown Robotics Team 1323
Unread 20-01-2016, 01:00
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
My team had some pretty good experience using versaplanetaries over the past years.
I was assembling ours today with the 775s pro on a 25:1 reduction (2 stages). 8 motors and 8 transmissions total. I had 2 of them overheating more than the others. (turns out stages were rubbing on each other) Gears are mounted on shafts that tend to get loose. We always punch them to avoid them getting loose and grinding on the stage below. We also used a different grease with the 775, since it has a much higher rpm. You want something more fluid, that will not put too much effort on the gears. After tuning each motor and gearbox, I got them at 3 to 3.5 amps each on 12V. No more sounds of gears grinding or overheating, and it sounds like a jet engine
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 20-01-2016, 01:13
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
The first thing I do after assembling a versaplanetary is grab a wrench or a wheel with a 1/2" hex and just see how easily the output shaft spins by hand. I've had occasions where something wasn't right and we were getting some binding / friction that you could definitely feel by hand while turning the output shaft. As others have mentioned, I'd recommend disassembling, inspecting and re-assembling and compare the 'feel test' to your existing assembled gearbox.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 20-01-2016, 01:51
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
This might be a dumb question, but what is the ambient temperature of your workspace? Just noticing OPs location, and given the hemisphere and time of year... Just a thought.
We hooked one of our new 775pro motors to a 36:1 two stage (plus encoder stage) VersaPlanetary last week and did not notice any excessive heat buildups during the time we ran it (which was, granted, only a few minutes).
Echoing what others have said, make sure to check your gearbox alignment and lubrication and make sure you're using the correct mounting plate for your motor. If you remove the motor and leave the rest of the gearbox assembled, you should be able to rotate it smoothly by hand at almost any reduction (assuming you're using a hex output shaft, it's a bit harder to grip the round ones).
In my experience, the only failure I've seen on a Versa Planetary was on my teams 2014 robot. The gearbox was at 100:1 reduction running a Bag motor (that stalled quite frequently) on our shooter. When switching out the Bag motor (which had fried) for the more powerful Banebots 775, the gearbox was still quite hot, and the brass(?) hub connecting the motor to the stage above it cracked in half just from trying to re-tighten the set screw. Beyond that, somewhat specific case, I've never had any issues with them that weren't quickly identified assembly user errors.
Unread 20-01-2016, 07:37
I just want to clarify a few things so we can all be on a similar page.
The VP gearboxes are pretty thin walled in the ring gear stages and they are made from aluminum alloy machined from an extruded block (in order to get them that thin).
This exacerbates any heat coming from the motor plus the heat generated by the gears during normal operation plus any binding due to misalignment.
The 775pro runs extremely fast compared to the other motors of its size and that is due to the ball bearings. It reduced friction by about 10-15% over the same model with bushings. As a result, the speed will cause the VP gearbox to get a little hotter than compared with the BAG, etc. This is normal. What is not normal is pulling more than 4 Amps (at 12 Volts) while running in your hand while connected to a single stage VP gearbox.
If this is happening, then you probably have some binding in the gearbox somewhere or you do not have enough lubrication.
Referencing the user guide below should help you greatly:
http://content.vexrobotics.com/vexpr...e-20151221.pdf
If you continue to have problems and you think there is something wrong with your specific VP gearbox, then please contact:
prosupport<the at symbol>vex.com
Paul
