Go to Post I'm sure someone somewhere worked [I]really hard[/I] on this and I congratulate them for the attempt. Unfortunately, its one of those things that should be taken down and recorded in the company journal as a bad idea. - Katie_UPS [more]
Unread 20-01-2016, 07:12
StephenNutt StephenNutt is offline
FRC #0172 (Falgor)
StephenNutt is an unknown quantity at this point
Re: Driving up the portcullis
We've had the same idea too. There are ball bearings on the sides at the top, and I believe a wheel at the bottom that will roll along a track.
You should allow for more than 5lbs of force - motors should generally be run at under 50% of maximum torque and you should account for some friction too.
Please post back and let me know how things work for you.
Unread 20-01-2016, 07:26
TheGabe's Avatar
TheGabe TheGabe is offline
FRC #1259 (Paradigm Shift)
Team Role: CAD
TheGabe is an unknown quantity at this point
Our team tried this. We have a few of the four inch anymark wheels (checkered tread) on the frount of our intake mechanism. We decided to try it. Only about half of the wheel is exposed toward the gate so we were able to roll the gate up and it rested on top of our wheels. From there we lifted the intake mechanism up and drove under. Our portcullis is made out of wood and has the 5lb lift force. This is how we plan on tackling this defence during competitions.
Unread 20-01-2016, 08:30
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Great to hear it! We're also planning to double-duty our intake rollers to raise the portcullis. Better go back and check the forces, though!
