Go to Post ... as teammates we often get too into the craze of competition and forget that this wouldn't happen without so many dedicated people. - miketwalker [more]
Unread 20-01-2016, 07:39
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Re: Heat/Friction of 775 + Versaplanetary
Lots of good info/thoughts.
We're pretty confident we've got the right amount of grease etc. We've used the versaplanetarys before without issue.
Originally Posted by R.C. View Post
To confirm,
OP are you using the piloted versaplanetary plates or the metal plate?
We are indeed using the plastic (injection moulded?) plates from some of the more recent versaplanetarys.
Originally Posted by cbale2000 View Post
This might be a dumb question, but what is the ambient temperature of your workspace? Just noticing OPs location, and given the hemisphere and time of year... Just a thought.
Haha, good question! Outside we're seeing temperatures of ~40 C, but I don't think we'd ever see more than ~30 C inside. While an interesting factor, I don't think it can explain the massive power draw on idle.
From the sounds of it the most probable explanation is alignment issues. However since we've pulled this gearbox apart and put it together multiple times, I don't think it's a simple user error. We'll get the students to swap out the motor plate tomorrow and see how that goes.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 20-01-2016, 11:11
Paul Copioli Paul Copioli is online now
President, VEX Robotics, Inc.
One common thing I have seen people do is get the input housing and output housing rotated 90 degrees from where they should.
The bolt patterns for the motor mounting and the VP assembly holes are not on the same diameter, but are close enough that they can be brute forced to "work".
The easy way to tell is to make sure the side bolt holes on the input and output slice are facing the same direction. If they are 90 degrees apart, then you will have problems.
Finally, if you think there is just something wrong with the alignment, then please contact our support. With the tolerances so tight on these gearboxes sometimes a few parts won't mate quite like intended.
As a side note, in the first year we actually sold pre-assembled single stage gearboxes and tested them for current draw. However, strong customer feedback was that the customer wanted to only buy the 1:1 (aka input and output + hardware) and buy the planetaries and ring gears separately. Once this happened, full testing was no longer possible and we needed to rely on our tolerances of the individual parts.
Any, I hope this helps you determine what is going on.
Paul
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 20-01-2016, 20:59
mman1506's Avatar
mman1506 mman1506 is online now
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
We are having a similar issue with the 775 pro and VP. We are drawing 30w when the output stage is not in place (normal) and 180w draw when the 1/2 hex output stage (1:1) is in place. We've tried two different output stages both with a reasonable amount of lithium grease.
2016: FRC 865 Mentor
Unread 26-01-2016, 09:55
squad1706's Avatar
squad1706 squad1706 is offline
You can't skeet the Skoat
AKA: Skoat
FRC #1706 (Ratchet Rockers)
Rookie Year: 2015
squad1706 is an unknown quantity at this point
We are also having a similar issue. We put together a 15:1 ratio versa-planetary, and after running it free on the table for about 3 seconds the planetary set was already quite a lot warmer, after an additional run of about 10 seconds to work some of the grease around (and yes, I have read the thread, there is a safe, but adequate amount of grease in them) they were approaching a temperature close to being too hot to hold. We are using all the proper VEX parts, and are put together identically to our others on our swerve system(obviously not the same ratio or motors). The ones on our robot however haven't ever gotten very hot, not until this 775 was hooked up to a set did they heat up.
Unread 26-01-2016, 15:45
Drew_trak's Avatar
Drew_trak Drew_trak is offline
AKA: Drew Petrak
FRC #0599 (Robodox)
Drew_trak is an unknown quantity at this point
Does anybody know the proper lubricant to use on a Versaplanetary gearbox? brand? Link? We are planning on using a 775pro attached to a VP 28:1 ratio if that affects what to use.
Thanks!
Unread 26-01-2016, 16:02
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Thanks!
Page 12 of the user guide says "A liberal application of white lithium grease is required on all gears."
Richard Wallace
since 2003
