Go to Post When you start new threads, keep in mind that ChiefDelphi has about 14.6 million subforums about nearly everything you can imagine in the world of FIRST. You have to be in the forum you'd like for your thread to appear in when you choose to start a new topic. - Madison [more]
Unread 17-01-2016, 10:45
Andrew Duerner Andrew Duerner is offline
FRC #5818
Andrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud of
775pro encoders
Hi Everybody,
We have more 775pro encoders in stock. These directly attach to the back of the 775pro motor. 12 counts per rev, quadrature encoding.
http://www.armabot.com/encoders.html
Best wishes for your robot builds!
Andrew Duerner
Mechanical Engineer
Owner/Operator - www.armabot.com
Mentor FRC1717 2012-2013
Mentor FRC5818 2016
Armabot and FRC team involvement are unaffiliated.
Unread 17-01-2016, 12:12
Re: 775pro encoders
What do you mean by 12 "counts" per rev?
A quadrature encoder has 4 edge transitions per cycle.
Do you mean 12 cycles per rev, or 12 edge transitions per rev?
Unread 17-01-2016, 13:38
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: 775pro encoders
Good question.
How many RISING edges per channel per rev?
Also, how well are the falling edges positioned wrt the rising edges (how close to 50% duty cycle is it?)
Finally how well are the two channels oriented (90 degree being optimal -- thus quad in the name)?
Dr. Joe J.
P.S. Can you share a screen shot of an o-scope trace of the two signals?
P.P.S. Can you provide some photos of the sensor assembled on the motor?
Team #88, TJ2
Unread 17-01-2016, 14:23
Re: 775pro encoders
Yes, that would be a very clear way to specify it.
In their datasheet for the E4P, US Digital calls the former "symmetry" and the latter "quadrature delay". See attachment.
Name:	E4P phase specs.jpg
Unread 17-01-2016, 16:21
iambujo iambujo is offline
FRC #2729 (Storm)
iambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to all
Re: 775pro encoders
Interesting concept Andrew. Do you have any detailed photos of the design and how it functions on the motor? Does it work by placing something (magnet? optical disk?) on the backshaft of the 775Pro?
Unread 19-01-2016, 03:11
FRC #5818
Re: 775pro encoders
12 edge transitions per rev. I'll get some pictures up tomorrow. Have a good evening!
Andrew Duerner
Mechanical Engineer
Mentor FRC5818 2016
Unread 19-01-2016, 07:28
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: 775pro encoders
Per Channel or Per BOTH Channels?
I suppose you must mean that each channel has 12 edges because this is possible with a 6 pole magnet (N-S-N-S-N-S) and you'd get an edge at each N>S or S>N transition.
I'm not sure how to even do the alternative.
Screen shots of O-scope traces of the two signals showing a full rev. would be great.
Dr. Joe J.
Team #88, TJ2
Unread 19-01-2016, 16:28
FRC #5818
Re: 775pro encoders
Exactly, each channel, the disk has six magnetic poles.
Attached are some pictures of the design.
Name:	RS7 encoder front.JPG
ID:	19817  Click image for larger version
Name:	RS7 encoder side.JPG
Andrew Duerner
Mechanical Engineer
Mentor FRC5818 2016
Unread 20-01-2016, 11:08
FRC #5818
Re: 775pro encoders
Here is a screenshot of the waveform for an unloaded 775pro motor running at around 9 volts.
Name:	encoder waveform.jpg
Andrew Duerner
Mechanical Engineer
Mentor FRC5818 2016
Unread 20-01-2016, 11:37
Re: 775pro encoders
Very noticable quadrature error.
Unread 20-01-2016, 12:03
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: 775pro encoders
Yes, and the duty is not very close to 50%, either.
The two channels will be useful for telling which direction the motor is turning. Using more than the rising (or falling) edges of one channel will add jitter to the speed measurement, making the speed loop either less effective, or increasing sensitivity of its stability on tuning.
In a shooter geared 2:1 per Ether's recommendation, this gives maybe 7 or 8 useful speed samples during the loaded part of a shot. The speed regulator will be trying to boost voltage to compensate that ~ 8 millisecond load transient, with boost adjustments 16 times per millisecond (controller output modulation frequency). It will be interesting to see how well the 775pro, this encoder, and a Talon SRX can regulate wheel speed during a shot load. Factors to influence the regulation include shooter wheel moment of inertia, speed regulator tuning, supply voltage feed-forward, ball compression, wheel compression, wheel-to-ball friction, etc.
Richard Wallace
since 2003
Unread 20-01-2016, 13:05
philso philso is offline
FRC #2587
Re: 775pro encoders
Are those "downward" spikes in the first Hi period on the left and the two High periods at the right of the blue trace real? Can you post a scope shot with the scope set up with long/infinite persistence?
Unread 21-01-2016, 22:34
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: 775pro encoders
Dr. Joe J.
I am an idiot some times. For Hall effect sensors, one pole, one edge*
12 edges would need 12 poles (N-S-N-S-N-S-N-S-N-S-N-S).
Joe J.
*unless it was one off those "reed switch replacement" Halls that go on based on the field strength being above a threshold in either the N or the S direction, this would be a terrible choice for this application so I think we can all agree that me being an idiot at times is the best answer and move on.
Team #88, TJ2
Unread 21-01-2016, 22:39
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Re: 775pro encoders
My one of my mentors wants to know if they can handle 19000rpm
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 21-01-2016, 23:01
Re: 775pro encoders
Well, it was designed specifically for the 775Pro whose free speed is 18730 so I would hope the sensor can mechanically and electrically handle that speed. Andrew, can you post an oscope trace at full speed?
As for the FPGA, the new higher FPGA sampling speed should handle it, even with the quadrature errors shown on the oscope trace posted earlier in this thread:
19000	rpm
316.7	revs/sec
3	cycles per rev (assuming 6-pole magnet w Hall sensor)
4	edges per cycle (quadrature)
12	edges per rev (quadrature)
3800	edges/sec (quadrature)
40.7	quadrature error (degrees)
182.6%	quadrature error (percent)
6937	edges/sec (with quadrature error)
If you are going to use this for speed control of a shooter wheel, follow the advice Richard gave in his earlier post and use rising edges only in one channel only, to give the cleanest (jitter-free) speed signal (especially if using bang-bang control).
Name:	RS7 symmetry error.jpg
ID:	19843  Click image for larger version
Name:	RS7 quadrature error.jpg
