Go to Post Everyone has regrets in robotics- it's how you learn from them that makes all the difference. - Kevin Leonard [more]
Unread 20-01-2016, 13:18
Pike3543's Avatar
Pike3543 Pike3543 is offline
Coder
AKA: Connor
FRC #3543 (C4 Robotics)
Pike3543 is an unknown quantity at this point
Camera Causing rio to reset
When we connect to the rio wirelessly we are able to control the robot but it only works for a few seconds before it re sets itself. So the connection light on the drive station flashes on then off and then connects automatically afterwards. It stays disconnected for 1 or 2 seconds. I have determend that the problem has something to do with the camera. Because when I upload the simple vision code it works fine but when i put it into our main robot code it doesn't work. Also the camera's blue light turns on but in the main code or when I upload a code without any camera code in it, the blue light turns off. I tried taking the camera out of both the code and the rio but that did not fix the problem ethier. I may be mistaken and it aint the camera, so if anyone has any suggestions please let me know. (We code in c++)
Unread 20-01-2016, 13:23
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: Camera Causing rio to reset
The blue light turns on when the camera is active. When it's not in use, the light should be off.
As to the reset issue, i'd watch the power LED during operation to see what the RIO itself is doing. If it's actually resetting, I'd check the wiring (power & ethernet) before blaiming the camera.
Unread 20-01-2016, 13:40
Pike3543's Avatar
Coder
AKA: Connor
The Rio aint losing power just the rsl light goes from fleshing to solid to flashing, so it goes from enabled to disabled to enabled. As for the wiring i double checked that everything was in and working properly. And the Ethernet is in properly
Unread 20-01-2016, 14:18
Pike3543's Avatar
Coder
AKA: Connor
If it helps here is the error message from the drive station console
Warning 44004 FRC: The Driver Station has lost communication with the robot. Driver Station
Warning 44002 Ping Results: link-bad, DS radio(.4)-bad, robot radio(.1)-GOOD, cRIO(.2)-GOOD, FMS-bad FRC: Driver Station ping status has changed. Driver Station
Warning 44002 Ping Results: link-bad, DS radio(.4)-bad, robot radio(.1)-bad, cRIO(.2)-bad, FMS-bad FRC: Driver Station ping status has changed. Driver Station
Unread 20-01-2016, 14:53
c0d3rman's Avatar
c0d3rman c0d3rman is offline
Programming Captain
AKA: Yoni Lerner
FRC #4904 (Bot Provoking)
c0d3rman is an unknown quantity at this point
Take a look at the red text here: http://wpilib.screenstepslive.com/s/...1-new-for-2016
