Go to Post FIRST is about so much more than what happens on the field, and sometimes we forget that. - Lil' Lavery [more]
Unread 18-01-2016, 21:56
paul.dornfeld paul.dornfeld is online now
FRC #5523
paul.dornfeld is an unknown quantity at this point
Cameras mounted on the bot: How many?
1. What is the limit (either bay way of rules, or driver-station capabilities) on the number of cameras that can be mounted and used on the bot?
2. Can more than one be viewed from the driver-station, if so, must they be viewed one-at-a-time or can multiple cameras be viewed simultaneously?
Unread 18-01-2016, 22:07
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: Cameras mounted on the bot: How many?
Having never used multiple before (though we might use two this year), take this with a grain of salt:
Cameras beyond 2 (if USB) or 1 (if Ethernet) require a hub of some kind to simply get more ports. With the default driver station, you will only get one stream at a time. If you have multiple views at a time up on screen, watch out for bandwidth usage.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 18-01-2016, 22:14
FRC #5523
Thank you.
And congrats on your (nearby) gas prices. National news:
http://www.cnbc.com/2016/01/18/gas-w...ents-here.html
Unread 18-01-2016, 22:25
Originally Posted by paul.dornfeld View Post
Thank you.
Nearby? Houghton Lake is nearly 400 miles from Houghton.
Unread 18-01-2016, 22:29
FRC #5523
Whoops! I better dust off the atlas. Sorry.
Unread 19-01-2016, 20:56
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
I have not found a rule regarding the number of cameras. That said, there are USB bandwidth limits to simultaneous operations. It is possible to simultaneously transmit multiple cameras across the network and display them on the drivers station if desired. It is also possible to switch between cameras one at a time. I posted some code last year that did the switching.
What do you need? I may be able to dig something up.
Unread 19-01-2016, 23:09
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We have three camera requirements, (auto targeting forward, driving forward, rear boulder pickup/driving in reverse for some defenses), but we're going to try to keep our camera count down to one or two. We're considering options to include changing camera parameters on the fly, mounting the camera on a servo, and using a mirror (or set of mirrors) to eliminate at least one of the cameras.
Unread 20-01-2016, 00:43
FRC #5523
Thank you so much for the offer. If needed, we will let you know.
Unread 20-01-2016, 00:44
FRC #5523
Great suggestions with the mirrors. Thank you.
Unread 20-01-2016, 08:11
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
If you put a parabolic mirror over your robot one camera can see all directions except straight up. Use software to unwarp the image to a panoramic. Not sure if anyone really needs that but it can be done.
Example
Unread 20-01-2016, 10:15
FRC #5523
Example
Amazing. Thank you.
Unread 20-01-2016, 13:42
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Can you post a link?
We might have a forward and rearward facing camera.
Thanks.
Unread 20-01-2016, 14:59
One Eyed Man
Found the link. The code may need some repairs.
http://www.chiefdelphi.com/forums/sh...94#post1437894
It's also possible to feed both simultaneously to the driverstation if that is desired. Be warned: Bandwidth limits tally up quick.
Unread 20-01-2016, 15:39
Thank you
