Go to Post When a vomit shooter runs out of balls, is it dry heaving? :p - Lil' Lavery [more]
Unread 20-01-2016, 13:16
btcshields6 btcshields6 is offline
FRC #4206
btcshields6 is an unknown quantity at this point
6 CIM Drivetrain with E4Ps
Hey guys! If I have a 6 CIM drivetrain, 3 CIMS per side, do I only need one E4P per side? So two total? The CIMS are in custom gearboxes. I'm using Talon SRXs. If you need more info, please ask.
Thanks!
Unread 20-01-2016, 13:43
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Re: 6 CIM Drivetrain with E4Ps
Most people put the encoder on the gearbox output shaft and therefore only need one per gearbox (two total per bot in the case of tank drive)
You will need to include any gear reductions after the gearbox output shaft (i.e. chain sprocket reductions) and the wheel size to calculate the wheel velocity and distance traveled.
-matto-
Unread 21-01-2016, 14:30
FRC #4206
Okay. Thanks!
Also, how do I connect an E4P to an SRX? The SRX seems to have a specific cable available, but is there a way I can connect the E4P to it directly? I looked over the appropriate section in the Talon SRX user manual, but I'm still not seeing a clear solution.
Unread 21-01-2016, 15:10
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
http://www.vexrobotics.com/217-4398.html
Unread 21-01-2016, 16:50
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
There are also other boards available. I prefer this one as I'd rather crimp connectors than solder.
http://www.chiefdelphi.com/forums/sh...d.php?t=135507
