Go to Post I understand that Dean Kaymen has now invented a super "sniffer" that can scout-out anyone within hearing distance that is remotely-involved with FIRST. - dhitchco [more]
Unread 20-01-2016, 19:37
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Encoder Breakout Sending signal from fwd limit switch
On our robot there are two limit switches, each with 2 motors connected. Since the motors are opposite each other one switch has the fwd limit of one, and the rev of the other. For some reason on one of the talon breakouts is sending a signal from the fwd switch. When they are both connected to the same 'outlet' on the switch, the motor thinks rev limit switch is true, even though the physical limit switch is false. This problem goes away when only one motor is connected to the physical switch. Any ideas?
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 23-01-2016, 18:37
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Encoder Breakout Sending signal from fwd limit switch
Do you have both talons programmed to be expecting the correct type of limit switch / encoder input? It may be expecting something else and trying to perform a handshake on that pin you're connecting the limit switch to.
Unread 23-01-2016, 20:34
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
The obvious (though impractical) solution is to use a double pole limit switch. Check out the "slave" mode that can be used for Talon SRXs operated by CAN. There may be an option that lets one slave to the other running in the reverse direction. Alternately, you may have to use the cRIO to monitor the limit switch on one and send the signal to the other.
Unread 23-01-2016, 20:53
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Yeah I'm not sure I follow the goal. Can you just have just have one master talon with traditional limit switch setup, and then have the slave talon follow the master. When the master limit-switch-faults, the slave will disable.
You can tell the slave to drive in the opposite direction. So master and slave are opposite in direction. See talon srx software reference manual section 9.1.4.
