Go to Post This is a very cool robot. It doesn't look like a launcher... it looks like a lifter driving backwards. Then whammo! The ball is flying through the air. - dtengineering [more]
Unread 20-01-2016, 19:46
iSpotix iSpotix is offline
FRC #4049
iSpotix is an unknown quantity at this point
Some questions about GRIP
Our team has been learning GRIP and I've gotten it to publish data to the Network Tables on localhost. I think we want to run it on our Driver Station.
1. How can I find the IP address of the Network Tables server created by the roboRIO?
2. Is there a way to test for rectangularity? Either through opencv or using the perimeter and area published by GRIP.
http://imgur.com/gallery/5DmVBAM/
Say if I had this image and I wanted to filter out the other target or other extraneous blobs that we detect.
Unread 21-01-2016, 01:24
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Re: Some questions about GRIP
You don't need to specify this - just set the team number and GRIP will figure it out. GRIP v1.1.0 will make this clearer by actually filling in the text in the settings dialog instead of just silently doing it.
GRIP v1.1.0 (which will probably be released within the next 24 hours) has a new solidity filter that should help with that.
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
Unread 21-01-2016, 02:05
Turing'sEgo Turing'sEgo is offline
Turing'sEgo can only hope to improve
Check to see if GRIP has approxpoly(DP). OpenCV has it, but I am not certain about GRIP. As the name suggests, it approximates a polygon out of a contour given an epsilon tolerance. You can read about the algorithm here.
