Go to Post No matter what you do and how well you try to protect them, some people are just out there to be candidates for the Darwin Awards! - Jay H 237 [more]
Unread 16-01-2016, 21:39
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Best place to get double solenoids?
We are trying to make our order for double solenoids, and the new ones from AndyMark have too few in stock to fill our order. We would like to get ones that are similar in function to the FESTO or CKD, but not with the same small fittings that won't stay in. Does anyone have any suggestions?
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 16-01-2016, 21:45
AustinShalit's Avatar
AustinShalit AustinShalit is offline
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Re: Best place to get double solenoids?
We use SMC solenoids purchased through Vex. We like that everything is in one place and the manifold aids in mounting.
Unread 16-01-2016, 21:49
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
Automationdirect has industrial solenoids that a lot of teams use and you can get them for free if you use the voucher in the KOP. And ADC ships 2-day via Fed-ex.
http://library.automationdirect.com/...rst-voucher)!/
These are probably larger than what you are used to, so note the size and weight before ordering.
Unread 16-01-2016, 22:19
Would this be an appropriate solenoid to use in FRC? I'm sorry for asking about this, but we want to make sure before we buy it.
Unread 17-01-2016, 13:40
They also require the use of a secondary pressure release valve, per R76 and R77-D.
Unread 20-01-2016, 12:32
rfolea's Avatar
AKA: Rick Folea
Apologies for the delayed response .. yes they would be appropriate, but see Joe's comment ...
Unread 20-01-2016, 12:46
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
We've used SMC and the Automation Direct solenoids (or a variant of that type anyway). Both work well but the question is what do you need. The SMC are small/light and more expensive (you can also buy from Vex Pro). The Automation Direct solenoids are significantly larger & heavier but cheaper. The Automation Direct solenoids also have significantly higher flow rates (I think CV is the measurement unit) which is useful for catapults.
Unread 20-01-2016, 13:46
RoboChair's Avatar
AKA: Devin Castellucci
You also have the option of a 2 position single acting solenoid. The difference being that the valve has a normally closed/open configuration which moves to the default position unless power is being supplied to the solenoid. The awesome benefit of using this type of solenoid is that at the end of the match when your robot powers off, the solenoid does as well and will return to the default position. So it you have an intake that uses one, it would lift back up at the end of the match. If you use it on a climber mechanism, you don't have to rely on pushing a button to trigger the climb, you just have to get it hooked on before the buzzer.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 20-01-2016, 21:29
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Robochair brings up a good point. Many of the kids on our team though a double-acting cylinders require a double solenoid valves, when a single solenoid/spring return valve will work fine.
Mentor, Team 3489, "Category 5"
Ashley Ridge H.S. & Summerville H.S.
Summerville, SC USA
Unread 20-01-2016, 21:40
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Be careful with this. I don't think I've ever seen it become an issue at a competition, but in the event of E-Stop, you want your robot to stop. With single solenoids, a disable or E-Stop can result in another movement, which can potentially result in a more dangerous situation. We only use single solenoids for smaller, more enclosed cylinders. Preferring to have arms etc on a double solenoid.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 21-01-2016, 02:06
RoboChair's Avatar
All our intake arms in 2014 were set up this way, but you are correct in that caution should be applied based on the energy potential of a given mechanism.
Unread 27-01-2016, 13:13
TomLockwood's Avatar
TomLockwood TomLockwood is offline
Lead Mentor
FRC #5712 (Hemlock's Gray Matter)
TomLockwood is an unknown quantity at this point
You've had good luck with the VEX manifolds (base stations)? They look like a very convenient solution.
