Go to Post Gracious professionalism is a two-way street. - Bharat Nain [more]
Unread 20-01-2016, 14:51
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Rubber(?) tubing used as wheel/roller traction material
I remember seeing multiple posts about teams using some sort of rubber (urethane?) tubing from McMaster as traction material for wheels and rollers that came in outer-diameters as high as 4". The idea being that that you could stretch the material over the roller or wheel.
I have found latex tubing on McMaster but the OD only goes up to 1.5". Does anyone have a source for something larger? Or maybe has a link to one of the old threads talking about it? For reference I believe the old CD threads were about using tubing to make custom intake wheels for Recycle Rush.
Unread 20-01-2016, 15:05
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: Rubber(?) tubing used as wheel/roller traction material
You're looking for polyurethane tubing: http://www.mcmaster.com/#catalog/122/3601/=10rmz4b
Goes up to 2.5" ID.
I believe it was AdamHeard who had a spreadsheet for what VexPro pulleys you could put it around to make wheels.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 20-01-2016, 15:39
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Additionally teams have had success with Gum Rubber tubing from McMaster.
Unread 20-01-2016, 16:04
BoilerMentor BoilerMentor is offline
FRC #1747
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
Silicone is a pretty solid option if you're looking for grip and it's available from mcmaster up to 2.75" OD. There are some tricks using inflation or an evaporating liquid lubricant, like ethanol to slide it on. We're using Silicone over PVC with custom 500 hex plugs.
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
2015-Present Ri3D Team Indiana - Mechanical and Fabrication
Unread 20-01-2016, 22:35
Monochron's Avatar
Engineering Mentor
Goes up to 2.5" ID.
Thanks that's exactly what I was looking for. Urethane tubing "without the "poly" returns a much smaller subset of IDs.
And the other suggestions of gum rubber are great, thanks for that as well.
Unread 21-01-2016, 09:34
philso philso is offline
FRC #2587
It was pretty funny seeing people's reaction to Pit Admin announcing our request for "alcohol" at a regional.
Unread 21-01-2016, 15:30
Monochron's Avatar
Engineering Mentor
Do you happen to know how grippy and how wear resistant gum rubber is compared to polyurethane? Everything I have found indicates that poly is a bit more wear resistant but I'm not familiar enough with either to guess how well it would hold up during competition.
Unread 21-01-2016, 15:42
Jacob Paikoff's Avatar
Jacob Paikoff Jacob Paikoff is offline
FRC reunion tour
FRC #0079 (Krunch)
Jacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant future
We have used drawer liner from Home Depot for years as a roller material and it works great. Link
In 2009 we experimented with a number of different styles until we found one that worked the best and used it that year, 2012, 2014 and will again this year.
Not exactly rubber tubing, but it might be useful.
Team 79, Krunch 2007-2010 Student
Team 2059, The Hitchhikers 2011-2014 College Mentor
Team 5402, The Iron Kings 2015 Mentor
Team 79, Krunch 2016 - Mentor
Unread 21-01-2016, 16:09
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
If you are looking for this to cover intake rollers I am not sure it is needed.
We prototyped with plain ole PVC pipe and those grippy balls got sucked right in.
Just sayin
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 15-03-2016, 21:18
RoboAlum RoboAlum is offline
Mickey D's
FRC #4841 (Optimal Robotics)
RoboAlum is a jewel in the roughRoboAlum is a jewel in the roughRoboAlum is a jewel in the roughRoboAlum is a jewel in the rough
Just sayin
How has that pvc intake held up or did you move away from the idea?
Co-Founder and Director
RASA (Robotics.Alliance.of Southern Arizona) 501c3
FRC 4841 2013-
VEX 4874 2013-
Student
FRC 71 2010-2013
