Go to Post Dean may have asked that every high school in America be involved with FIRST, but he never said [teams] all had to have separate high schools. - Amanda Morrison [more]
Unread 20-01-2016, 23:49
Seth179662 Seth179662 is offline
FRC #3606
Seth179662 is an unknown quantity at this point
Solenoid Recommendations
My team may be looking to use pneumatics for a catapult this year. We are not very experienced with pneumatics and we're wondering what solenoid would be best for activating pistons quickly to get the catapult launch we need. We will probably be using 2 double acting pistons with 8 inch stroke for launching.
Unread 21-01-2016, 06:51
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: Solenoid Recommendations
So our 2014 bot lessons learned... Automation Direct high flow solenoids. Also, you probably want to use Single Solenoids and the pistons should only have the shooting direction hooked up to a solenoid. The returning direction should not be pressurized. To return the catapult to the starting position, gravity is used. This reduces the amount of backpressure/resistance when shooting.
Unread 21-01-2016, 07:39
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
In 2014, we used a single acting solenoid with P/N 6124K511 from McMaster-Carr, and we were very satisfied with them. However, I would recommend having two of them and directly hooking the output to the input on the cylinder to get the least amount of distance the air has to travel to fill the cylinder. Also, have the return port of the cylinder simply be open, because gravity will just pull it down and force the air out of the bottom once the solenoid switches back to vent.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 21-01-2016, 09:04
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
An air tank on the 60 psi side of the regulator with a short hose or direct connection to the solenoid input wouldn't hurt, either.
Unread 21-01-2016, 13:13
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Double check the rules. In past years they limited us to one solenoid valve per cylinder. If that's the case this year, you can use two smaller cylinders with one valve each, to get the maximum speed.
Mentor, Team 3489, "Category 5"
Ashley Ridge H.S. & Summerville H.S.
Summerville, SC USA
Unread 21-01-2016, 13:24
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
The pneumatic rules this year allow for check valves as long as the they don't prevent all pressurized air from being released when the main vent valve is opened.
R77 G. Check valves, provided that the requirements of R89 are still met
Something like this would allow you to still return the cylinder using air pressure from the other side of the solenoid but have the advantages of release the air to atmosphere instead of returning it to the solenoid exhaust port. This may not be quiet as fast as just venting to atmosphere but it should be close.
From the product spec sheet.
NITRA pneumatic push-to-connect in-line quick exhaust valves
have a technopolymer body and nickel-plated brass valve insert,
with a range of 7 to 150 psi. Normal flow is from inlet to outlet
ports. Reversing flow from outlet is directed to exhaust port. These
valve are ideal for use with pneumatic actuators that require a
very fast stroke speed.
Unread 21-01-2016, 13:30
FRC #3606
Would two of these do well?
Unread 21-01-2016, 13:46
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
This is the same solenoid and setup we used in 2014, worked great! The other useful tricks, as mentioned above, are
  • Hook the solenoid right to the pneumatic cylinder (see pic below)
  • Leave the other end of the cylinder completely open (no hose or fitting is needed, gravity will bring the catapult arm back down)
  • Put a small tank right in front of the supply side of solenoid so that the air doesn't have to go through the regulator. This tank is at the 60psi working pressure.
We may or may not be using two of these solenoids on our robot this year.
Unread 21-01-2016, 14:06
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
We've built air catapults successfully before using a round electromagnet from mcmaster.com, http://www.mcmaster.com/#5698k116/=10s4olc
fast valves aren't that important in my experience. What is important is that you must not retract the piston all of the way. Leave a 'chamber' of air about 2 -4 inches in the bottom of the air cylinder when your mechanism is retracted and position your mechanism so that it doesn't have much leverage against the catapult when it starts.
Fill the cylinder(s) while holding the magnet. when the cylinder is up to 60psi, release the magnet. The 'chamber' of air will 'explode' the catapult forward.
Unread 21-01-2016, 18:01
When I said two, I meant order two and have one per cylinder. I can see how what I said would be interpreted that way though.
Unread 21-01-2016, 19:01
FRC #3606
I have looked through all the recommendations and I think this solenoid would work best. It's a 3-way 2 position and it seems good to me. I would just like confirmation from someone more experience with pneumatics to confirm it is good and also legal.
Unread 26-01-2016, 14:53
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The same ones we use when only plumbing to one side of the cylinder. It is not the correct one for extend/retract. For that you need what Automation Direct calls a "5 port" Like this
The only real issue is the valve is rated for 115 PSI working pressure so you need a downstream relief valve per R77-D
Unread 30-01-2016, 11:06
jfitz0807 jfitz0807 is offline
FRC #2877 (Ligerbots)
Team Role: Parent
jfitz0807 is an unknown quantity at this point
We're planning to go with a setup like s_forbes. We have a 1.5" bore, 4" throw cylinder and we're shooting reasonably well using just the standard Vex solenoid/manifold through about a foot of tubing to the cylinder. We're optimistic about using the higher flow solenoid directly connected to the cylinder.
We're trying to figure out how to wire the solenoid. The picture only shows "12V" with arrows pointing to the two parallel leads. I'm not sure what that means. The PCM only has a black and a red wire. Do we connect red to one and black to the other? Does it matter which is which? What do we do with the third lead?
And oh, by the way, we'll be using 24V so we'll get a 24V solenoid.
Any guidance is appreciated.
