Go to Post FIRST may very well be the healthiest drug on the market. - Herodotus [more]
Unread 21-01-2016, 07:27
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: We're building 20 sets of bumpers...
Originally Posted by MrBasse View Post
We heat press our numbers. Vinyl runs about 2 buck for four sets of numbers. Cutting takes a machine that can do it, we use a vinyl cutter or our schools laser engraver. That takes around 10 minutes to cut all four sets. Pressing takes around ten minutes using a t-shirt press.
If you don't have the equipment it would be costly to start. But once you have that stuff you can make a lot of cool things with a laser, vinyl cutter, and heat press.
Could you provide a link to the heat press vinyl you use?
The views expressed are mine and should not be construed to represent the views of anyone else.
