Go to Post Bottom line: if it confuses my mom, it is bad for FIRST. - Joe Johnson [more]
Unread 21-01-2016, 08:02
Re: roboRIO Not Communicating Until Reset
When it is being non-communicative, I have some diagnostics that will help us figure it out.
Please click to the second DS tab and see what the ping LEDs look like. Also look on the third tab to see that the team number is correct. Click on the arrow next to the team number and see if your robot shows up. Shift-click on the arrow and see if the robot name shows up then.
Finally, go to a web browser and enter in roboRIO-team-frc.local where team is your team number and see if the browser can connect.
Please report the results along with what type of interface you were using, USB, enet, wifi. If using USB, also use 172.22.11.2 in the web browser and see if that works.
Also, what type of laptop, vendor and OS?
Greg McKaskle
