Go to Post If Will uses the word "dope", doesn't wear a larger FIRST logo, takes up half of the St. Louis arena, if there was not enough seating in the pits, if the music was killed during finals, it was all justified tonight. - Barry Bonzack [more]
Unread 21-01-2016, 00:50
kitare102 kitare102 is offline
AKA: Eric
FRC #3042 (Cobalt Catalysts)
kitare102 is an unknown quantity at this point
Gearing a Rotating Arm
Our current robot design includes a dual-flywheel shooter on an angle-adjustable arm which we are currently trying to figure out how to rotate. For reference, the arm can be approximated by a mass of 3.5kg at .3m from the pivot. Our question is what would be a good way of gearing the arm such that it is responsive. To make another approximation, let's say "responsive" means traveling from horizontal (0 degree) to 45 degrees in .5 seconds, which should really be taken as a guideline over a restriction for the design.
The current model involves a versaplanetary (motor and stages undecided) followed by a sprocket stage which is necessary for the placement of the gearbox but can be made a reduction anywhere from 1:1 to around 4:1. Is a versaplanetary a good choice for this situation? If so, where to go from there and if not, what other options have teams used?
Unread 21-01-2016, 01:03
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Gearing a Rotating Arm
JVN calculator is my go-to for rotary stuff. Just plug in your ratios and it spits out speed.
For your application, I get a speed of 0.27 seconds to go 90* if I used 2 miniCIMs on 100:1 versaplanetaries (no extra reduction).
Unread 21-01-2016, 01:11
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Just a heads up, that speed sounds like it could be quite fast if you are looking to control the arm accurately, and you might want to play around with it a bit. I don't know the specifics of your mechanism, but you could probably mess with the chain reduction part of it to get it to a quick controllable speed in any case, and that would probably only require the minimal maintenance of changing sprockets. This is by no means a must-do, but it might be something you'd want to keep in mind.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 21-01-2016, 03:42
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
No arms please
Unread 21-01-2016, 06:58
waterbott's Avatar
waterbott waterbott is offline
FRC #1683 (Techno Titans)
Team Role: CAD
waterbott is an unknown quantity at this point
Originally Posted by JohnSchneider View Post
No arms please
Out of curiousity why would you suggest against that? Our team is looking on doing something similar
Unread 21-01-2016, 07:15
Joseph Smith's Avatar
Joseph Smith Joseph Smith is offline
Persistence alone is omnipotent.
FRC #3539 (Byting Bulldogs)
Joseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant future
No arms please
The Second Amendment begs to disagree
Design/fab team 2011-2013
Design/fab mentor 2014--
There are three types of people in the world:
1. Those who make things happen
2. Those who watch things happen
3. Those who wonder what happened.
Unread 21-01-2016, 08:12
Jarren Harkema's Avatar
Jarren Harkema Jarren Harkema is offline
Dancing Drive Coach
FRC #4967 (That ONE Team)
Jarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to all
Two teams wanting to work with severed arms? Wow... Where are you sourcing these spare body parts?
Unread 21-01-2016, 08:18
Ginger Power's Avatar
Ginger Power Ginger Power is online now
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Their 2015 Robot could have something to do with it...
I think the teams in question are dicussing a very different kind of arm though. If I'm picturing it correctly, it's just a pivoting intake/shooter on a lever arm. A very simple concept as there is just 1 range of motion to worry about.
Unread 21-01-2016, 08:55
Back in 2011 when we had a long arm, we used gas springs on moment arms to balance the weight of the arm. If you do it right, the arm will stay at any position you put it without having to stall the motor to hold it there. A sprocket or gear bolted directly to the arm, driven by a miniCIM in a 100:1 planetary with a decent secondary gear/sprocket reduction should get the job done.
Unread 21-01-2016, 08:56
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant future
You may want to tone down the speed if you are rotating the shooter up and down at those angles unless the "boulder" is firmly secured you could lose it when rotating.
Team member 2004-2008
Team mentor 2008-20XX
http://team1708.steelcityrobotics.or...tics/Home.html
"Education is a powerful tool. Always use it to better someone else's life"
Unread 21-01-2016, 09:00
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If you can swing that heavy an arm that fast, why not just remove the dual-flywheel shooter and its motors and throw the boulder a bit faster?
Unread 21-01-2016, 09:15
Chris is me's Avatar
AKA: Pinecone
Arms can be tricky!
I would avoid driving a long lever arm with a live 1/2" hex axle, and I would avoid driving one directly off a VP, especially 100:1. The 10:1 VP stages are the least strong, and arms exert a lot of shock loading that can really do nasty things to the thinner gears of the VP.
How many positions does the arm need to be in? 2, 3, 4? If at all possible, using pneumatics to rotate the arm between a few positions will simplify control a great deal and is generally more durable.
If you must motorize a long lever arm, it's probably best to do the final reduction for the arm using chain, with the sprocket bolted to the arm to transmit torque. 973 RAMP has some good videos on how to design a simple durable arm power transmission system. The chain can deal with some of the shock loading the arm will face a bit better than a final gear stage could, as there is some flex in the chain and the sprockets are engaged at multiple teeth versus 1 or 2 teeth for a geared system.
Your gearbox will almost definitely backdrive, though you may be able to feed-forward the motor at a small voltage to prevent this. Only do this at low voltages or your motor will heat up quite fast.
Unread 21-01-2016, 09:16
AKA: Eric
To answer a few questions and raise some more...
The arm is relatively short, and only rotates about one axis. The ball is contained by the arm as it moves, so the ball falling out isn't a concern.
Now, according to the chart here: http://content.vexrobotics.com/vexpr...e-20151221.pdf (page 25, miniCIM simple load ratings) a miniCIM is not recommended for a versaplanetary at a reduction of 100:1. How should I interpret this?
Thanks for the help so far, everyone.
Unread 21-01-2016, 09:33
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
1) JVN Design Calc is very good for this sort of thing
2) Read and understand your chosen transmission's applications manual there are a number of motor/gearing combinations that quickly exceed VexPro's recommendations (or bane-bots, or whatever). For example: running a mini-cim with a 2x10:1 vesaplanetary is counter-indicated, but running a mini-cim with a 9:1+4:1+3:1 gives you 108:1 reduction and is approved. I recall that when BB planetaries were first used widely in FRC there were a number of complaints about the transmissions failing, and it was because they simply weren't rated to deal with an RS775 geared down 256:1 (for example).
[moving on from addressing the above post]
3) Arms can usually stall to hold position, but you must make sure this current is acceptable (see JVN calc for this). I've designed arms that stalled RS775s to hold position with no issues, use your judgement here
4) If you counter-balance, and I think most arms should be counter-balanced, I suggest working out the spring geometry to counteract gravity. I.e. you want the most counter-balancing torque when the arm is horizontal, and the least amount (or zero) when it is vertical (meaning its CG is over the pivot point).
5) Some amount of damping on your counter-balance is fantastic for smooth control. We really like using air cylinders to counter-balance because they provide a constant restoring force, damping, and mechanical hard-stops all in one.
6) Back to actual arm gearing... my general practice is to pick the power I want the arms to have, which drives my motor decision. I gear as much as possible with a planetary transmission, staying inside the MFGs load guides, then I do I final sprocket reduction to the arm itself. Sprockets let me keep my drive motors down low in the robot, and generally help with arm packaging (many small details that I won't go into here). Chain is also a great place to couple on an encoder for arm control.
Examples of 95 robots' arm gearing:
2011: 2xRS775 + 64:1 bane bots + 14:72 sprocket reduction (IIRC), motors were mounted under the 'deck' of the robot, shoulder joint was near the height limit. Motors stalled to hold position. Some minor pneumatic counter-balance
2015: 2xCIM + 50:1 versa planetary + 16:64 sprocket reduction, pneumatic counter-balance kept arm neutral without game pieces, motors stalled to hold position. This robot needed over-balance protection in code since it could pick the arm+game piece up fast enough to flip itself over.
Unread 21-01-2016, 09:39
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
No arms please
Woah woah woah! You guys were the masters of arms last year!
GitHub
