Go to Post I got Vista with mine. It's like getting moldy fruitcake for Christmas. - Koko Ed [more]
Unread 01-17-2016, 04:22 PM
Bernstern Bernstern is offline
FRC #2141 (Spartonics)
Rookie Year: 2015
Bernstern is an unknown quantity at this point
Roborio Image does not match plugin
BUILD FAILED
C:\Users\robotics\wpilib\java\current\ant\build.xm l:227: Assertion failed boolean test.
roboRIO Image does not match plugin, allowed image version: 23
This is a problem that keeps coming up as we attempt to deploy to our prototype.
We have imaged the rio 3 times with the new labview v 19 file.zip and have updated our java problems to no avail.
Unread 01-17-2016, 04:25 PM
Re: Roborio Image does not match plugin
As you have noticed, you can update to 2016v19 as much as you want and it will still fail if your plugins are looking for 2015v23. Install the plugins using either of the methods described near the bottom of this document: http://wpilib.screenstepslive.com/s/...eclipse-c-java
Eclipse will detect that you already have plugins installed and offer to update instead.
Unread 01-17-2016, 04:26 PM
It looks like you haven't updated the eclipse plugins.
Unread 01-17-2016, 04:57 PM
Rookie Year: 2015
When i went to eclipse and checked for plugin updates, it said it was current and i validated with the FRC software site.
Unread 01-17-2016, 05:00 PM
So you have the correct version of the plugins installed as confirmed with this page? http://wpilib.screenstepslive.com/s/...ware-revisions
If that's the case, for some reason the plugins must be failing to update the files. Close Eclipse, delete your C:\Users\USERNAME\wpilib directory (where USERNAME is your username), then open Eclipse again.
Unread 01-17-2016, 05:10 PM
Make sure Eclipse is set to use the release site, not stable or development. Those are out of date compared to release.
Unread 01-17-2016, 05:15 PM
Rookie Year: 2015
Ok so that did the trick, now im getting error remote command failed exit status 1
Unread 01-17-2016, 05:41 PM
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Deploy again. Without the entire console output, this error usually pops up because no robot code is running when it tries to cancel the current running code.
Unread 01-17-2016, 06:13 PM
Post the full contents of the console window please. That message is not particularly helpful by itself. It means one of a whole slew of remote commands run on the roboRIO failed. Some of them can fail harmlessly, others will prevent the build from continuing, but we can't tell which one failed or how to fix it without the whole log.
Unread 01-20-2016, 09:17 AM
jwatson12 jwatson12 is offline
Mr. Watson
FRC #1025 (Impi Warriors)
jwatson12 is an unknown quantity at this point
Make sure you are using this years FRCUpdates and that your RoboRio has the matching image.
Unread 01-20-2016, 12:49 PM
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
That should be safe to ignore. It tends to pop up when there is no robot program already on the rio (which causes the kill command to fail)
Deleting the wpilib directory and restarting eclipse solved the problem for me as well. You can also go into the build.xml file and just remove the assertion.
Unread 01-21-2016, 10:59 AM
BenD BenD is offline
FRC #4828 (Swift Creek RoboEagles)
BenD is an unknown quantity at this point
If you're receiving the error remote command failed exit status 1 but your code is going through and the program builds successfully, then there is no issue. euhlmann explains it well above.
If the error is causing your build to fail, make sure you have the correct JRE on the RoboRIO.
