Go to Post "John V-Neun - The Thing / Ken Patton - Mr. Fantastic" I don't think a better description of these two people have ever been posted on ChiefDelphi. - Amanda Morrison [more]
Unread 21-01-2016, 13:13
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Re: Solenoid Recommendations
Originally Posted by 3175student17 View Post
However, I would recommend having two of them and directly hooking the output to the input on the cylinder to get the least amount of distance the air has to travel to fill the cylinder.
Double check the rules. In past years they limited us to one solenoid valve per cylinder. If that's the case this year, you can use two smaller cylinders with one valve each, to get the maximum speed.
Mentor, Team 3489, "Category 5"
Ashley Ridge H.S. & Summerville H.S.
Summerville, SC USA
Unread 21-01-2016, 13:30
Seth179662 Seth179662 is offline
FRC #3606
Seth179662 is an unknown quantity at this point
Would two of these do well?
Unread 21-01-2016, 18:01
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
When I said two, I meant order two and have one per cylinder. I can see how what I said would be interpreted that way though.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 21-01-2016, 19:01
FRC #3606
I have looked through all the recommendations and I think this solenoid would work best. It's a 3-way 2 position and it seems good to me. I would just like confirmation from someone more experience with pneumatics to confirm it is good and also legal.
Unread 26-01-2016, 14:53
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The same ones we use when only plumbing to one side of the cylinder. It is not the correct one for extend/retract. For that you need what Automation Direct calls a "5 port" Like this
The only real issue is the valve is rated for 115 PSI working pressure so you need a downstream relief valve per R77-D
Unread 30-01-2016, 11:06
jfitz0807 jfitz0807 is offline
FRC #2877 (Ligerbots)
Team Role: Parent
jfitz0807 is an unknown quantity at this point
We're planning to go with a setup like s_forbes. We have a 1.5" bore, 4" throw cylinder and we're shooting reasonably well using just the standard Vex solenoid/manifold through about a foot of tubing to the cylinder. We're optimistic about using the higher flow solenoid directly connected to the cylinder.
We're trying to figure out how to wire the solenoid. The picture only shows "12V" with arrows pointing to the two parallel leads. I'm not sure what that means. The PCM only has a black and a red wire. Do we connect red to one and black to the other? Does it matter which is which? What do we do with the third lead?
And oh, by the way, we'll be using 24V so we'll get a 24V solenoid.
Any guidance is appreciated.
