Go to Post Sometimes, you just have to beat something (someone?) into submission. Yes, you can use your head, but its a lot easier with a hammer. - Andy A. [more]
Unread 21-01-2016, 14:16
CryptoStorm's Avatar
CryptoStorm CryptoStorm is offline
EIC Tech
AKA: Joshua Stilwell
FRC #5056 (MegaHurtz)
CryptoStorm is an unknown quantity at this point
How many CIMs in your drivetrain?
I started as a FIRST student in 2004. to my knowledge we've always used 2 CIMS per side on the standard "tank drive" type setup. We used mecanum wheels once which required independent drive of 1 CIM per wheel.
Does anybody have any (scientific) input on using only 1 CIM per side? (2 total)
how about 6 CIM drive?
Unread 21-01-2016, 14:57
pfreivald's Avatar
AKA: Patrick Freivald
Re: How many CIMs in your drivetrain?
We prototyped a 6 CIM drive during the offseason using VexPro's dog shifting dual-speed gearboxes, and it works fantastically.
We also did octocanum for about five years, and could beast through just about everyone...except for 6 CIM drivetrains, despite being geared down about as preposterously low as you could get, and with great traction.
I would strongly recommend not going to one per side--you'll lose every pushing match you get into with a four-CIM drivetrain, and each of those CIMs are going to draw more current, work harder, get hotter, and drain your battery more than four or six. The only advantage is weight, and it's not a good enough tradeoff.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 21-01-2016, 15:11
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
has anyone ever done a drivetrain with more than 6 motors? (not including steering for swerve)
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 21-01-2016, 15:37
Here's a quick calculation using MCALC to compare
one CIM drawing 60 amps at 12 volts
vs
two CIMs each drawing 30 amps at 12 volts:
Motor Calculator  build MCALC_2014d 2/3/2014 1255pm
Select motor:
1)CIM     6)FP0673   d)FP2719  f)FP9012     g)FP9015    h)FP9013 j)MiniCIM
a)am-0912 b)am-0914  7)DensoL  8)DensoR     c)Denso0160 k)BAG    u)UserDefined
2)RS395   3)RS540    4)RS550   e)RS775-12   5)RS775-18  m)RS555  n)am-0915
r)am-2193 s)am-2235  t)RS390   v)RS545      p)am-2161&2194
w)VEX2177hi  z)VEX2177std  1
CIM FR801 001, AM802 001A @ 12.00 volts:
@ free (no load):
   oz-in      Nm     rpm    rpm%    amps   watts out  watts heat    eff%
     0.0   0.000    5310   100.0     2.7         0.0        32.4     0.0
@ stall:
   343.4   2.425       0     0.0   133.0         0.0      1596.0     0.0
@ max power:
   171.7   1.212    2655    50.0    67.8       337.1       477.1    41.4
@ max efficiency:
    42.8   0.302    4648    87.5    18.9       147.1        80.2    64.7
Select input:
1)oz-in  7)watts_in    3)rpm    5)amps   b)rpm&amps  8)eff%
2)Nm     6)watts_out   4)rpm%   9)volts  a)rpm&ozin  m)main menu   x)exit 5
enter amps: 60
   151.0   1.066    2975    56.0    60.0       332.2      387.8    46.1
Select motor:
w)VEX2177hi  z)VEX2177std  u
Enter the following motor specs in the order and units indicated,
separated by spaces or tabs:
volts   stall_ozin      free_rpm        stall_amps      free_amps
12       686.8           5310             266            5.4
UserDefined-> 12.0 686.8  5310 266.0  5.4 @ 12.00 volts:
@ free (no load):
     0.0   0.000    5310   100.0     5.4         0.0        64.8     0.0
@ stall:
   686.8   4.850       0     0.0   266.0         0.0      3192.0     0.0
@ max power:
   343.4   2.425    2655    50.0   135.7       674.2       954.2    41.4
@ max efficiency:
    85.6   0.605    4648    87.5    37.9       294.3       160.4    64.7
Select input:
enter amps: 60
   143.9   1.016    4197    79.0    60.0       446.6       273.4    62.0
one CIM drawing 60 amps at 12 volts:
332 watts output mechanical power
388 watts waste heat
447 watts output mechanical power
273 watts waste heat
Unread 21-01-2016, 16:44
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We did a 2 CIM drivetrain last year, but Recycle Rush was definitely a special case; you didn't want to accelerate quickly or drive very fast. We're starting with 4 this year, and if we change it, we'll be going to six.
I've read about people considering 4 CIM + 4 min-CIM designs for Mecanum and 4-wheel Killough, but was unable to find any examples that had been built and played.
Unread 21-01-2016, 17:29
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Here you go
That year we ran 4 CIMs + 4 Mini-CIMs in our shifting 8in Mecanum Drivetrain. Looking back, mecanum probably wasn't the best choice that year with the heavy defense (), but we sure tried our hardest to make it work. For the most part it did, and we were able to handle many defensive situations with the great traction of the extremely wide wheels, but the cons far outweighed the benefit.
With 8 CIM-motors, we had the potential to run 320 Amps of current into our drivetrain before any of the individual 40A breakers would trip. Even operating well below that, there was incredible risk for popping the main breaker, not to mention browning out components, both of which happened in matches on multiple occasions. In high gear, any defensive situation was almost always a brown-out and radio reboot on the field. In low gear, we had maybe 10 seconds before a brown-out. With the current sensing capabilities of the new PDP, careful software could allow a team to more safely run this kind of setup, but back then, it was far more risk than the team could effectively manage or I would ever recommend.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 21-01-2016, 22:16
EIC Tech
We talked about using 6 cims for a all terrain off season robot. I've got a couple 36v motors I'm going to donate though.
The team is considering 2 CIM drive this year. I'm not recommending that, especially with tank treads. I think they will change their minds when they see how poorly it performs after the chassis is built. Hopefully we can drive it this weekend.
Maybe I'll be proven wrong though..
Unread 21-01-2016, 22:56
EIC Tech
vs
Select motor:
@ free (no load):
@ stall:
@ max power:
@ max efficiency:
Select input:
enter amps: 60
Select motor:
@ free (no load):
@ stall:
@ max power:
@ max efficiency:
Select input:
enter amps: 60
Wouldnt a 1/4 hp motor and a 1/2 hp motor consume the same amount of power if the continuous load only required 1/8 hp. Amperage being based on load.
I know that 2 cims will be capable of more torque, I'm just wondering how noticeable it will be from the perspective of the driver.
Unread 21-01-2016, 23:18
Take a careful look at what I posted:
332+388 = 720 total watts consumed (one CIM)
447+273 = 720 total watts consumed (two CIMs)
They both consume the same power @ 12 volts @ 60 amps, but you get more output mechanical power and less waste heat with two CIMs.
So you don't need as many amps with the 2 CIMs to get the same output power as 1 CIM.
Unread 21-01-2016, 23:19
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We had 2 added 2 more today. Only problem is we were only able to get one screw in each Cim. We will try more probably making a tool to get in there but, we sadly have run a drive train an entire season using 1 screw per Cim and can verify it works.
Unread 21-01-2016, 23:56
EIC Tech
You're specifying X amount CIMs at 60 amps. It is manufacturing a theoretical load that will require 60 amps.
The load is different.
What happens if you specify a load?
Unread 22-01-2016, 00:00
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud of
We are going to be running either a 6 CIM drive or a 4 CIM drive depending on our lift mechanism. At this point in the build we are using the 6. 3 on each side.
Team member 2004-2008
Team mentor 2008-20XX
http://team1708.steelcityrobotics.or...tics/Home.html
"Education is a powerful tool. Always use it to better someone else's life"
Unread 22-01-2016, 00:50
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
General rule of thumb for motors (at least what I was taught in college): A motor is most efficient when run exactly at the rated power output. More or less will result in a drop in efficiency. Obviously the latter is a better scenario than the latter, but in terms of % efficiency, all else being equal, going overkill isn't an improvement.
That said, it's far easier for a 2 cim drive to get pushed past the rated output, and given that batteries are usually recharged between matches, the time when efficiency (for realistic practical FRC purposes) counts is under full load (read: shoving match), so that's why a 2 cim drive will overheat and (probably) draw more amps in such a scenario.
The reason 6 cim drives lead to brownouts is not a motor issue per se; it's simply that such a drivetrain has more capability than a single battery can provide (at a voltage that the control electronics/VRMs can handle). So, realistically, in a FRC legal robot, you'll never see the full potential of a 6 cim drivetrain. You may see more than a 4 cim, sure, but you'll probably never get to full load simply because the battery can only give so much power (internal resistance is the limiting factor assuming good battery wiring). Hence the need for brownout prevention for such drivetrains.
Unread 22-01-2016, 00:59
Jared Russell's Avatar
Taking a year (mostly) off
Maximum power and maximum efficiency occur at two separate points on the motor curve for brushed DC motors.
Maximum power occurs when P(out)=radial velocity * torque is maximized, which is at half free speed and half stall torque.
Maximum efficiency occurs when P(out) / P(in), or (radial velocity * torque) / (current * voltage) is maximized. This always occurs somewhere between the maximum power point and free speed (it varies from motor to motor depending on free current).
Unread 22-01-2016, 01:05
The max power (rated power) of the DC brushed motors used in FRC occurs at roughly half the free speed.
The max efficiency occurs at a higher speed.
EDIT: Jared beat me to it.
