Go to Post I actually love and am very thankful for what all these amazing engineering role models put into this program year in and year out. - Bill Gold [more]
Unread 21-01-2016, 17:12
Mechvet Mechvet is offline
Certified Public Menace
FRC #0114
Mechvet is a jewel in the roughMechvet is a jewel in the roughMechvet is a jewel in the rough
Re: pic: Harbor Freight 8 inch tire on 3d printed hub
Originally Posted by MrBasse View Post
If anyone is interested, I updated my file and will post a Thingiverse link tomorrow. They seem to hold up okay, but we haven't aggressively tested yet. That won't be done until next week, unfortunately.
What infill percentage did you print these at? Also, infill pattern?
Unread 21-01-2016, 18:07
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
I don't have control over my infill or patterns with a Stratasys machine, so we went with near solid fill. However, we did destroy our first hub this afternoon. I would love to say that I will still update and post CAD for these, but I don't want a failure coming back to haunt us with bad juju. If you do decide to print hub, make sure that the flange is very stout as that is what de-laminated on us.
It was a fun experiment, but unfortunately it wasn't meant to be.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 21-01-2016, 23:42
FRC #0114
Interesting. Which part broke exactly?
EDIT: Did another read through. So if the hub delaminated, are you printing in ABS?
I think we'll print one of these up in PLA at ~20% infill, and see what happens. I'll post results here after we're done.
Unread 22-01-2016, 06:44
The bead flange specifically is what broke. We were counting on theses more than we should have, so now it's time to scramble. We can still drive the thing around, but it reminds me of my first truck I had when I was 16. The broken wheel is held in place only by air pressure on one side now, so it has a wicked wobble and can't move very fast without eating itself.
Andrew Basse
Unread 22-01-2016, 08:19
onenerdyguy onenerdyguy is offline
FRC #5929
onenerdyguy is on a distinguished road
We were in a very similar situation, and sorta still are.
I'm currently printing a pair of these hubs at 100% infill on PLA, to see how they hold up. 20 hours to go.
Our current driver is running on AndyMark hubs (was lucky enough to get them in before they went out of stock) and Amazon 200x50mm wheels. We found that, like many have said, the hubs don't line up with the bead. We were able to adapt this by using the metal hub that came with the wheel initially, hacking it up a bit, and epoxy'ing them to the hub.
So far, holding well. Have been aggressively testing it over the rock wall, moat, rough terrain with no noticeable issues.
Unread 24-01-2016, 22:56
72LML 72LML is offline
FRC #3184 (Blaze Robotics)
Rookie Year: 2015
72LML is on a distinguished road
MrBasse, do you have access to a lathe? It looks like you could turn some hubs with similar dimensions that should be stronger. Just a thought. We're in a similar situation but went with turned hubs to work with some Northern Tools tires and rims. They should work with any rim that has a 2.75" x 4 bolt pattern. If you're interested I can email you our CAD files if that would help.
Team #3184
Blaze Robotics
Burnsville, MN
