Go to Post It's a good things we're engineers who regularly squeeze out 'miracles' with a severely limited budget, eh? I think that's an important aspect that we as mentors need to show the students from time to time, and this year is a perfect opportunity. - JesseK [more]
Unread 19-01-2016, 21:15
ejscribner ejscribner is offline
Drive Team & Coach
FRC #2972
ejscribner is an unknown quantity at this point
navX MXP Import Issue
I'm working on setting up the navX on Java with our roboRIO. I've followed the steps listed in this tutorial http://www.pdocs.kauailabs.com/navx-...ibraries/java/ and I'm still getting an error with the import. Here's what the error is saying:
Buildfile: C:\Users\Developer\Documents\GitHub\DeltaBot\build.xml
Trying to override old definition of task classloader
clean:
   [delete] Deleting directory C:\Users\Developer\Documents\GitHub\DeltaBot\build
compile:
    [mkdir] Created dir: C:\Users\Developer\Documents\GitHub\DeltaBot\build
     [echo] [athena-compile] Compiling src with classpath=C:\Users\Developer/wpilib/java/current/lib/WPILib.jar:C:\Users\Developer/wpilib/java/current/lib/NetworkTables.jar to build
    [javac] Compiling 1 source file to C:\Users\Developer\Documents\GitHub\DeltaBot\build
    [javac] C:\Users\Developer\Documents\GitHub\DeltaBot\src\org\usfirst\frc\team2972\robot\Robot.java:22: error: package com.kauailabs.navx.frc does not exist
    [javac] import com.kauailabs.navx.frc.AHRS;
    [javac]                              ^
    [javac] C:\Users\Developer\Documents\GitHub\DeltaBot\src\org\usfirst\frc\team2972\robot\Robot.java:33: error: cannot find symbol
    [javac]     AHRS ahrs;
    [javac]     ^
    [javac]   symbol:   class AHRS
    [javac]   location: class Robot
    [javac] C:\Users\Developer\Documents\GitHub\DeltaBot\src\org\usfirst\frc\team2972\robot\Robot.java:54: error: cannot find symbol
    [javac] 	           ahrs = new AHRS(SPI.Port.kMXP);
    [javac] 	                      ^
    [javac] C:\Users\Developer\Documents\GitHub\DeltaBot\src\org\usfirst\frc\team2972\robot\Robot.java:169: error: package AHRS does not exist
    [javac] 	          AHRS.BoardYawAxis yaw_axis = ahrs.getBoardYawAxis();
    [javac] 	              ^
    [javac] 4 errors
BUILD FAILED
C:\Users\Developer\wpilib\java\current\ant\build.xml:69: Compile failed; see the compiler error output for details.
Total time: 3 seconds
And my import line looks like this:
Any ideas as to what may be causing this error?
Unread 19-01-2016, 21:21
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Re: navX MXP Import Issue
I believe a step or two in the java library configuration instructions was missed, specifically these one:
1) Add a Java Build Variable for the navX-MXP Java Library. To set the build variable, from the Eclipse menu select Window->Preferences->Java->Build Path->Classpath Variables, then click on the “New…” button. Then, in the “New Variable Entry” dialog, set the name to “navx-mxp” and set the Path to <HomeDirectory>\navx-mxp\java\lib\navx_frc.jar. Hit OK to save this change.
and...
2) Ensure that your project’s library paths include the navx-mxp variable, as well as WPI library path variables (networktables and wpilib). If any are missing, you can add them by clicking on the “Add Variable…” button.
If either the "navx-mxp" build variable is not present in the Eclipse Java ClassPath Variables settings - or if your project's library paths do not include this "navx-mxp" variable, the error message you have reported is the very likely result.
Unread 19-01-2016, 21:31
Drive Team & Coach
FRC #2972
and...
Thanks for your response! I've followed those steps and its still throwing that error. My thought is that there might be an issue with the classpath in the usage of slashes. Does it matter if they are forward or backslashes? It only seems to let me input forward slashes when I'm adding the classpath (it changes backslashes to forward slashes when I save it) but the error output seems all squirly with half forward and half backslashes as follows:
Do you think this may be a factor in the error?
Unread 19-01-2016, 22:24
Software Mentor
AKA: Scott Libert
I don't believe the forward slashes is where the problem lies.
The navx-mxp.jar file should be in the classpath. However, I don't see it listed in the classpath in your latest message (although I do see the WPI library .jar and I do see Networktables.jar). So I think the problem is that when eclipse builds your project, it can't find navx-mxp.jar. And that is confirmed by the complaint that it can't locate the AHRS class, which is contained within the navx-mxp.jar library.
Unread 19-01-2016, 22:37
Please post the build.properties of the project
Unread 20-01-2016, 12:20
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
since the navx jar is not showing up in the classpath, it looks like the build.properties is not set up correctly.
Unread 20-01-2016, 12:34
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
I believe the issue is that WPILib doesn't know where to find the navx jar file. You must configure the build.properties as shown here.
Unread 20-01-2016, 17:10
Drive Team & Coach
FRC #2972
The build.properties seems to be setup correctly according to the FRC tutorial on adding 3rd party libraries:
# Project specific information
package=org.usfirst.frc.team2972.robot
robot.class=${package}.Robot
simulation.world.file=/usr/share/frcsim/worlds/GearsBotDemo.world
userLibs=${user.home}/navx-mxp/java/lib/navx_frc.jar
Is there another issue that could potentially be affecting the classpath?
Unread 20-01-2016, 18:25
Software Mentor
AKA: Scott Libert
Are you sure you have installed the latest, released version of the WPI Libraries (installed by updating to the latest WPI plugins in eclipse)? The 2015 WPI library, and the 2016 betas, did not include the userLibs parameter. But the 2016 release version does. So I'd recommend you check your versions.
Unread 20-01-2016, 18:59
Drive Team & Coach
FRC #2972
I checked Eclipse and found that someone had turned off automatic updates, and so I did have an older version of the WPI Libraries, however after updating I am still confronted with the same error messages. Is it possible Eclipse did not update to the true current version?
Unread 20-01-2016, 20:58
Does it match the version listed here: http://wpilib.screenstepslive.com/s/...ware-revisions
Unread 21-01-2016, 17:58
Drive Team & Coach
FRC #2972
Our Java plugin version is (0.1.0.201601151923) which is listed as the latest version, but the kickoff version seems to be more recent (0.1.0.201601072029). When press the update button in eclipse it says that no updates were found, but if ours is the ...23 version and there is a newer ...29 version, shouldn't it find that version and update or am I missing something? Is ...23 more recent than ...29?
Unread 21-01-2016, 18:16
Volunteer, WPILib Contributor
no team (Waiting for 2021)
The whole last number is a date string, so 201601072029 was built on January 7th, whereas 201601151923 was built on January 15th. So you do have the newest version.
Team 4488 - Mentor 2013-2016
Unread 21-01-2016, 18:36
Drive Team & Coach
FRC #2972
Okay so we know the eclipse plugins are up to date. My error message has changed slightly to reflect that it is finding some sort of navX library, or at least its looking for one, as you can see below:
     [echo] [athena-compile] Compiling src with classpath=C:\Users\Developer/wpilib/java/current/lib/WPILib.jar:C:\Users\Developer/wpilib/java/current/lib/NetworkTables.jar:C:\Users\Developer
     [echo] avx-mxpjavalib
     [echo] avx_frc.jar to build
So now its looking for something in C:\Users\Developer\avx-mxpjavalib or \avx_frc.jar so I can clearly see that something is misspelled due to the "avx" instead of "navx" but I cant seem to find where it is misspelled. Where do I edit the filepath for this so that it is correct?
Unread 21-01-2016, 18:47
Software Mentor
AKA: Scott Libert
OK, we're making progress - now that you've got the correct WPI library version, the build is attempting to link to the navx library. But it appears that the path is wrong:
Here's what you entered in your build.properties:
But it appears that when eclipse is building, each time the "/n" characters are encountered, those characters are being treated as a new-line character.
It's interesting to note that the \n sequence (where \ is an 'escape' character) translates to an ascii new-line character, which is what eclipse appear to be outputting.
This is likely a system-specific configuration issue, and I'm going to recommend trying it on another system - or else identifying what it is in your system that is interpreting "/n" in file system paths as a new line character. I've see this kind of thing happen sometimes if a package like Cygwin is installed, although I can't remember the details off of the top of my head.
