Re: [FRC Blog] Our Mistake and Q612
... plane flight ... Me: "The assembly instruction and the drawing do not match. And they way they actually build it on the line matches neither document. The 1st, 2nd and 3rd shifts make it slightly differently" |
I like the new width - it's a nice number...
Speculation time. How big of a difference will 3/4" be when it comes to the majority of drivetrains already designed?
I actually think this is beneficial to a vast majority of drive systems. If the extra .75" is a deal breaker, then maybe what you're doing is a little too complicated.
The Rock Wall is 4.625" tall overall relative to the platform, it is 4.50" if you are not counting the thickness of the material that makes up the base flanges. So it will be 4.625" Tall and 5.25" Wide at Competition. |
I feel like I'm probably missing something huge here, but isn't 4.5x4.5 steel square tube a standard steel tube size? I've used it all the time for machine frame weldments, the corners are rounded too.
4.5 x 4.5 x 3/16 wall: http://www.metalsdepot.com/products/...ml?page=sqtube 4.5x4.5x.12 wall: http://www.tottentubes.com/square-steel-tubing I kinda assumed it was a solid steel tube, didn't expect them to make it bent sheet metal. I guess maybe the weight savings from not having the bottom wall? |
#8
The bent part is already made out of sheet steel. I guess you could TIG weld it if you want, but most welders I've met can do pretty clean welds with a MIG and steel is generally easier to weld than aluminum. The distortion issues are valid, but I think they could be avoided by a competent welder. |
#10
Glad to hear they're willing to re-make the Rock Walls to avoid giving teams a rock wall that's "too tall" out of spec! That could make a big difference!
As for the widening... if anything it should just make it easier to avoid high-centering. 4.625" tall x 5.25" wide. |
#11
Props to FIRST for their handling of this. This sort of thing happens all too often in engineering - it's a good experience for students to see. People make mistakes and hard decisions that impact customers need to be made.
