Go to Post Some companies cut costs (and cut corners to do so). Some work hard to build loyal customers. Which would you rather purchase from? - sanddrag [more]
Unread 21-01-2016, 18:59
Drew_trak's Avatar
Drew_trak Drew_trak is offline
AKA: Drew Petrak
FRC #0599 (Robodox)
Drew_trak is an unknown quantity at this point
Back Driving a Versa planetary gearbox
Does anyone know the amount of force it would take to back drive a Versa planetary gearbox 100:1 attached to a MiniCim? Thanks!
Unread 21-01-2016, 20:21
piersklein piersklein is offline
piersklein is a jewel in the roughpiersklein is a jewel in the roughpiersklein is a jewel in the roughpiersklein is a jewel in the rough
Re: Back Driving a Versa planetary gearbox
Are you running current through the motor?
2016 Boston Semifinalists
2016 UMass Dartmouth Creativity Award, Quarterfinalist
2015 Northeastern Quarter Finalists (6th rank)
2015 UMass Dartmouth Winners
2014 RISM Rookie Inspiration Award, Semifinalists.
2014 NorthEastern Rookie All-star, Highest Rookie Seed, Semifinalists.
2014 NECMP- Highest Rookie Seed
Unread 21-01-2016, 21:15
Drew_trak's Avatar
AKA: Drew Petrak
FRC #0599 (Robodox)
Yes - u have any advice on how much?
Unread 21-01-2016, 21:21
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Download the JVN calculator, go to the "Rotary mechanism" tab and input your stuff there if you haven't already.
A minicim has a stall torque of 12.4 in*lbs, so on a 100:1 reduction that's about 1240 in*lbs (minus efficiency losses). I personally don't like running motors with current for extended periods of time except on the drivetrain, and even then not really. I would try to get maybe a quarter of that stall torque max, but I have no basis other than experience for that recommendation. If you wanted to figure out exactly how long you can put a current on a motor, Vex has graphs for motor power and heating.
Unread 21-01-2016, 21:50
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Not sure what you are getting at. Are you asking, are you asking how much torque it would take to backdrive the MiniCIM through the 100:1 Versa Planetary when the robot is disabled?
For example you might be trying to winch your robot up and then not have anything other than the motor's cogging torque to keep the robot from falling?
If this is the case, I urge you to think again. My experience is that without something more than this you will have a difficult time preventing the system from backdriving. It is the kind of thing you can get to work... ...almost but that you'll be sorry about in the end.
It is not that hard to make a latch or a catch that prevents backdriving.
Dr. Joe J.
Team #88, TJ2
Unread 21-01-2016, 22:18
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
The root of the issue here is that you're running a mini cim through a 100:1 planetary, which is not recommended by VEXpro.
http://link.vex.com/vexpro/pdf/Versa...ry-LoadRatings
Unread 21-01-2016, 22:26
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
It only means that you can't stall the minicim without breaking the VP. You can still run them together.
Unread 22-01-2016, 00:04
kitare102 kitare102 is offline
AKA: Eric
FRC #3042 (Cobalt Catalysts)
kitare102 is an unknown quantity at this point
Look in the 3-stage section of the simple load ratings charts. Using more structurally stable stages, VEX greenlights gearing a miniCIM up to 108:1, so you can still use a legitimate configuration to reach that 100:1 reduction. That's what we'll likely be doing for one of our manipulators.
