Go to Post A good engineer will never stop learning. From his peers, technicians, and competitors. The field is just to vast for any one person to know it all. - Mr. Mike [more]
Unread 14-01-2016, 09:03
4373Henry's Avatar
4373Henry 4373Henry is offline
FRC #4373
4373Henry is an unknown quantity at this point
[Question] Library on roboRIO appears to be missing
I've been having some issues with the new roboRIO. Firstly, the code kept failing to deploy to the robot. The ANT build failed with a message saying that the firmware version didn't match. After I modified the file to print out both the version required and the version in use, I got that required was 19 and the one it got was "ImageRegExFail". I believe this comes from an error in the following:
<propertyregex property="roboRIOImage" input="${roboRIOSysValues}" regexp="FRC_roboRIO_2016_v([0-9]+)" select="\1" defaultValue="ImageRegExFail"/>
My the sysProps.xml file in the project is here
So I commented out the version check and ran again. The deploy succeeded with no errors, but when I opened the driver station, there was no code. I connected to the roboRIO through SSH and ran the code manually:
lvuser@roboRIO-4373:~$ bash robotCommand
➔ Launching «'/usr/local/frc/JRE/bin/java' '-jar' '/home/lvuser/FRCUserProgram.jar'»
Exception in thread "main" java.lang.UnsatisfiedLinkError: /var/volatile/tmp/libwpilibJavaJNI948982247454152796.so: libnirio_emb_can.so.15: cannot open shared object file: No such file or directory
	at java.lang.ClassLoader$NativeLibrary.load(Native Method)
	at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1929)
	at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1814)
	at java.lang.Runtime.load0(Runtime.java:809)
	at java.lang.System.load(System.java:1083)
	at edu.wpi.first.wpilibj.hal.JNIWrapper.<clinit>(JNIWrapper.java:47)
	at edu.wpi.first.wpilibj.RobotBase.initializeHardwareConfiguration(RobotBase.java:170)
	at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:182)
I tried updating the roboRIO again as well as uninstalling and reinstalling all the eclipse plugins but this had no effect. Has anyone else experienced this issue? I ran a few searches on CD and couldn't find the error.
Unread 14-01-2016, 09:24
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
You need to update the image on your RoboRIO. That's the reason why the build was failing: your RoboRIO is out of date. See the ScreenSteps here https://wpilib.screenstepslive.com/s...g-your-roborio.
Unread 14-01-2016, 10:18
4373Henry's Avatar
FRC #4373
Re: [Question] Library on roboRIO appears to be missing
I already followed those steps. Is 3.0.0f0 not the latest version?
Unread 14-01-2016, 10:30
ghead ghead is offline
FRC #3103
ghead is an unknown quantity at this point
Image != Firmware. Latest image is 2016v19. Follow the link given earlier and make sure you update to the latest.
Unread 14-01-2016, 15:46
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
We are having the same issue. We have Image v23, but it says we need v19 to run. We can't locate a link for this file. Any help would be great! Thanks!
Unread 14-01-2016, 16:59
WPILib Developer
FRC #0190
The link I gave in my last post in this thread is the relevant ScreenSteps article.
Unread 21-01-2016, 20:10
patlam patlam is offline
FRC #3374
patlam is an unknown quantity at this point
So we're having the same problem and seem to be missing the FRC Image 2016v19 image. We have installed the update suite and everything however we still cannot find the file... Is there any link to download the image?
Unread 21-01-2016, 22:21
mhamzaqayyum mhamzaqayyum is offline
FRC #6008
mhamzaqayyum is an unknown quantity at this point
Yep, same exact problem here, we have v23, but need v19. Cannot find it...
Unread 21-01-2016, 22:26
The short version?
Install the Update Suite from the instructions here: http://wpilib.screenstepslive.com/s/...-all-languages
Image using the instructions here: http://wpilib.screenstepslive.com/s/...g-your-roborio
The right version? Read through each of these in order (you may be able to just skim some of them) to make sure you're not missing things: http://wpilib.screenstepslive.com/s/4485/m/13503
