Go to Post Now, our team did meet, but there wasn't much inspiring going on. Unless you call pegging me with more darn poof balls exciting. - Paul Copioli [more]
Unread 21-01-2016, 23:13
mlyhoops mlyhoops is offline
AKA: Matthew Yamamoto
FRC #1197 (TorBots)
mlyhoops is an unknown quantity at this point
NETWORK TABLE HELP (ROBOREALM)
I was wondering if anyone knows how to get the Network Table values from RoboRealm to eclipse so I can use that data for vision tracking. right now we are just getting the default values for the network table. If you need a picture of the network table or the code then email me at mlyhoops@hotmail.com
Unread 21-01-2016, 23:19
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Re: NETWORK TABLE HELP (ROBOREALM)
I'm assuming you mean getting values from RoboRealm to your robot code. Eclipse is just the development environment. I will email you as well, but are you getting any error messages from RoboRealm? The most likely cause is that it's not connecting to the robot NetworkTables server. Did you see the note at the bottom of http://www.roborealm.com/help/Network_Tables.php regarding setting of the hostname to "roborio-xxx-frc.local"?
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 22-01-2016, 08:59
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Also, check out this thread on ChiefDelphi: http://www.chiefdelphi.com/forums/sh...d.php?t=142052
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
