Go to Post If there is water in the 2006 game, I will blame it on Gary. - dlavery [more]
Unread 21-01-2016, 21:00
Bluman56's Avatar
Bluman56 Bluman56 is offline
Mentor Without Borders
AKA: Nikita
FRC #2579
Bluman56 is a jewel in the roughBluman56 is a jewel in the roughBluman56 is a jewel in the roughBluman56 is a jewel in the rough
AndyMark 3CIM4U with Rhino Track Output Shaft Issues
Hey all,
As we were putting together the Rhino Track, it became obvious that there is a problem with the output shaft on the 3CIM4U being too short. We double checked with CAD to make sure everything was assembled correctly and short of removing the thinner of the two plates on the 3CIM4U, it doesn't seem there is much we can do.
Is anyone else using the combination of these two parts and having the same problem? Would appreciate some help. Thanks in advance.
Unread 21-01-2016, 21:29
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
Re: AndyMark 3CIM4U with Rhino Track Output Shaft Issues
we are not using this combo, but the fix is relatively simple if you have a lathe. Buy some 4140 1/2" hex stock and turn a new output shaft. If you dont have one, try talking to teams around you. This is a pretty quick job and it should not be hard to convince them to make it. If you cant find anyone local, I would be happy to make you longer output shafts if you purchase the material.
Unread 21-01-2016, 21:46
Bluman56's Avatar
AKA: Nikita
FRC #2579
We realized this is what we would have to do, it's just a little peculiar that we have to do it considering that the Rhino Track page specifically states that the 3CIM4U is compatible with it. I was hoping we were doing something wrong.
Unread 21-01-2016, 21:51
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Did you order it with a long output shaft?
Unread 21-01-2016, 21:55
Bluman56's Avatar
AKA: Nikita
FRC #2579
The 3CIM4U came with the long output shaft.
Unread 21-01-2016, 22:09
dradel's Avatar
Oh and you need to turn your axle bolts around. The bolt head is suppose to be on the out side plate
Unread 21-01-2016, 23:44
Bluman56's Avatar
AKA: Nikita
FRC #2579
Duly noted.
Unread 22-01-2016, 00:13
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Did you contact AndyMark? If not, shoot them an email with picture(s) and I bet they'd be happy to help you.
Unread 22-01-2016, 11:06
dradel's Avatar
Also on that output shaft either make a spacer or what we did another 1/2" hex collar to press against the outer plate flange bearing. The flange bearing is "press fit " but will back out of the outer plate at least one of ours did.
Unread 23-01-2016, 09:38
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
I'm not sure it's a problem. The drive sprocket for the tracks are right next to the transmission, and the output shaft is supported at both ends by a bearing.
We used to use unsupported transmission shafts driving sprockets for years.
