Go to Post After assisting with the animation last year I realized how cool and useful Inventor was and I started flirting with it. Half a year later I think I have lost all possibility of ever having a girlfriend, and frankly I don't care because I would definately bare the child of this program. - negfrequency [more]
Unread 15-01-2016, 12:20
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Electrical parts keep breaking!
Originally Posted by dharg99 View Post
Also I recommend tinning wires to newbs, helps them understand the wires a lot more.
I would recommend you don't tin your PWM cables...
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 15-01-2016, 12:23
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
PWM cable system only need the white and black for proper communication... I believe the old motor controllers needed the red for extra power as their ability to send the pwm message was weaker than the new talons and victors
Also one thing I've learned being head electrical on my team is simply don't try if you don't know...
Electrical isn't like programming where you can hit backspace, in electrical things can burn, arc weld, explode, and kill you.
None of the FRC legal motor controls of the recent past have used the 5v signal wire in the PWM cable.
The way the motor controllers that I have looked at their schematics work is that the black and white wires are connected to an optoisolator. So all the signal does is light up an LED.
Unread 15-01-2016, 12:26
I believe the old motor controllers needed the red for extra power as their ability to send the pwm message was weaker than the new talons and victors.
If by "old motor controllers" you mean the Jaguar, Vic884, Vic888, VicSP, Talon, and TalonSR... then no, the red wire is not used.
Unread 15-01-2016, 12:32
The white wire is the signal wire, and the black wire is ground. Both are needed.
The red wire is power (not signal). It is needed only when the PWM cable is connected to a low-power servo motor. It is not needed for any of the motor controllers.
The signal (white) wire carries the PWM command on it.
Unread 15-01-2016, 23:33
dharg99's Avatar
dharg99 dharg99 is offline
FRC #4633
dharg99 is an unknown quantity at this point
Yes, those motor controllers, however victor SP should not be on that list as the don't use the red wire, it's only there as the stock pwm they get in manufacturing is used for all their products, they just cut the red on the Vic Sp's
#4633Lyfe
Unread 15-01-2016, 23:41
non sequitur. None of the motor controllers in that list use the red wire.
perhaps you meant it shouldn't be in the list because it's a new motor controller, not an "old" one.
Unread 16-01-2016, 00:56
Mr V's Avatar
FRC #5588 (Reign)
Yes I worded that very poorly. The red wire is connect to a 5V supply at the Roborio but is not connected to the circuitry of the motor controller.
The white wire supplies the actual signal to the motor controller.
Unread 22-01-2016, 08:16
Matt,
Can you be more specific? Under what conditions?
Unread 22-01-2016, 11:36
AKA: Matt B
FRC #1771 (1771)
Matt,
Sorry, I should have said the connectors, specifically the male end (the 3 pins).
The pins are already a semi-tight fit into the female ports, and tinning them shouldn't be needed to make them stay in. Hot glue around the connector would work better for that, if needed.
If the pins are being tinned because the signal is acting wonky, the wire itself could be broken at a certain point causing intermittent connections, or the crimping at the connector could be bad.
1771- Mentor (2015)
Unread 22-01-2016, 14:50
I agree that male pins should never be tinned. I also do not recommend hot glue. It rarely works like you want because the parts are too big to get hot enough and the glue will get down inside some devices and lift surface mounts parts off the board.
Unread 22-01-2016, 15:59
philso philso is offline
FRC #2587
How does that happen?
Unread 22-01-2016, 16:18
I believe it has something to do with rapid expansion and contraction during the application. We won't use hot glue.
