Go to Post You all are brilliant people. - Andy Baker [more]
Unread 22-01-2016, 10:08
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
AM-2971 Encoder Increasing Both Directons of Motor
So our motors are hooked up to the TalonSRX Encoder Breakouts, and the wiring is correct, but the encoder value we are reading on smart dashboard is saying the encoder value is increasing with both directions of the motor. Is there any reason for this?
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 22-01-2016, 11:38
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: AM-2971 Encoder Increasing Both Directons of Motor
Could you be more explicit with your setup? A particular configuration issue that could cause this is if you are using a simple (non-quadrature) encoder that cannot discern direction of rotation.
Unread 22-01-2016, 11:46
gordmaier gordmaier is offline
FRC #4917
gordmaier is an unknown quantity at this point
Can't help with the error, but had a question about the AM-2971 (started a separate thread) ... these AM-29** series motors are not on the legal list, and were we also hoping to used them. Is there some other location that lists these as legal?
Unread 22-01-2016, 11:51
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Are you talking about this motor? If so, it's an RS775 and is legal. It's listed under the BaneBots line.
http://www.andymark.com/Gearmotor-p/am-2971.htm
Unread 22-01-2016, 11:55
CDL_066 CDL_066 is offline
FRC #0066 (The Flyers)
CDL_066 is an unknown quantity at this point
AM-2971 is the motor/gearbox/encoder assembly. The motor itself is the AM-2765, which is a legal motor per R29.
