CIM motor testing
I'm looking to create a test to calculate (and hopefully rank) the performance of the many CIM motors in our robot closet.
The approach would be to have a CIM hooked to a winch, and hoist a known load up a known distance, and measure the time it takes. I've assigned several students the task to determine what these values should be, based on the datasheet curves and gearboxes we already have laying around. I'm going to try and target the test taking about 3-5 seconds, while using the FRC robot control system and components. I'm looking for any advice others might have, specifically how to control confounding variables that might skew the test results. One item I've already identified is battery discharge over the course of testing; I'm looking at purchasing a power supply to run the motor (in lieu of a battery). Was wondering if powering the setup from this would work (having trouble finding anything above the 1000W 12V range): http://www.ebay.com/itm/RC-POWER-SUP...-/301361360478 Keeping in mind that I'm not looking to stall the CIM for any amount of time. Also I'm wondering what sort of variations we'll see. Once again any advice is appreciated, I'd love to hear everyone's thoughts. |
Re: CIM motor testing
With the load switch open, close the power switch and record speed and current. Close the load switch and record speed and current. Open the power switch and install the next CIM to be tested. Repeat. You could also include a double-pole-double-throw switch to quickly reverse the power leads, and test in both directions. Last edited by Ether : 22-01-2016 at 11:20. |
I must admit, I didn't think of that.
I like the simplicity of the design, but the other part of this is I'm trying to keep a group of high schoolers busy with the project I might do that as a secondary test to see if the results align. Doing a little more research on power supplies, seems I might be able to buy a used server power supply with a single 12v rail and use that. HP Integrity RX6600 Server Power Supply Model RH1448Y PN: 0957-2198 Looks like it's rated at ~130A, and can be purchased for around $80. |
See my results from a few years ago, and VexPro's more recent three-minute power test results, to understand how internal motor heating reduces maximum power. |
Also thanks for the links, they're very good resources. As an aside, it looks like the VEX folks had motors catching fire in under a minute. |
#7
If you are using some system I would recommend the use of a micro switch at the end of a lift should you go with that method to measure the time from start to stop. Similarly I would recommend to lift weight as the motors won't be used at their no load ability on a robot. I also think that some consideration ought to be given to building a gearbox to change motors in and out of and measuring their individual power consumed and difference in speed.
#9
The proposed test rig with a "load CIM" puts a substantial load on the CIM being tested when the load switch is closed. Quote:
#10
Part of the testing will be to get the students to program the FRC controller to measure the time it takes for the test to elapse, and whether it's a micro switch, encoder count or some sort of photo switch (or combination thereof) is still yet to be determined. I'll be interested in seeing the difference in power characteristics. I'm not sure what we'll have available in terms of data logging, and I'm very curious to see how well the motors fit the datasheet. EDIT: Would you think that the energy the "load CIM" dissipates would change its resistance characteristics? Are there any steps we can take to mitigate the effect? Last edited by efoote868 : 22-01-2016 at 15:35. |
#11
Safety warning: If you decide to use such a setup, make sure to use a heavy-duty load switch and that is properly insulated/shielded (including cables). I'm not sure how much instantaneous voltage will be generated when the load switch is opened. Maybe someone (some adult) could test this. If the voltages are high enough to be a concern, a condenser (old-school term) -- like the ones that were used to keep the automobile distributor points from pitting back in the pre-electronic-ignition days -- could be placed across the load switch. |
#12
