Go to Post There will inevitably be enough unintentional failure in any endeavor we take on that adding intentional failure on top of that seems unnecessary. - Jared Russell [more]
Unread 22-01-2016, 11:33
gordmaier gordmaier is offline
FRC #4917
gordmaier is an unknown quantity at this point
RS775 with Encoder
Are these motors legal (PG27 Planetary Gearbox with RS775 Motor and Encoder (am-2923)) - or do we need to add encoders after the fact. And if so, can someone explain why?
http://www.andymark.com/Gearmotor-p/am-2923.htm
Unread 22-01-2016, 12:01
CDL_066 CDL_066 is offline
FRC #0066 (The Flyers)
CDL_066 is an unknown quantity at this point
Re: RS775 with Encoder
Yes, the motor itself is an AM-2194, which is legal.
Unread 22-01-2016, 12:02
FRC #4917
Thanks for the clarification, so as long as the base motor is legal, we can order different assemblies of it including encoders, gears etc...
Thanks
Unread 22-01-2016, 12:50
For the record:
It is virtually identical to an am-2194, but it is not an am-2194 motor. The am-2194 has a short back-shaft which does not interface with an encoder
It is an am-2766, which is also a 2016 FRC-legal motor. It's an am-2194 with a longer backshaft.
