Go to Post As far as we know, FIRST could replace football by 2018! - Adam Richards [more]
Unread 01-22-2016, 11:46 AM
Shu Shu is offline
FRC #2137 (TORC)
Shu is an unknown quantity at this point
Gearbox Ground Clearance Issues
We are looking at the Vexpro 2 CIM ball shifter with 3rd stage to direct drive the center wheels(all wheels are AM 8" pneumatic). I am mostly concerned with going over the rough terrain where the wheel is on a 1" block that is next to a 3" block. The gearbox hangs far enough below the frame to contact the 3" block. The orientation that gives the most ground clearance is with the output shaft and motors on the bottom and air cylinder on top. This leaves the large 3rd stage gear exposed which would have to be protected in some way. Is anyone else struggling with this and/or found a solution?
Unread 01-22-2016, 12:06 PM
Owen Busler's Avatar
Owen Busler Owen Busler is offline
Build Captain
FRC #0303 (Test Team)
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
Re: Gearbox Ground Clearance Issues
One of many possible solutions is to not direct drive the center wheel. If you were to move the gearbox to a higher location, and have the output shaft drive a gear/pulley/sprocket, you could power your middle wheel with a gear/chain/pully. This would also set up the possibility to power two wheels from the output shaft of the gearbox.
Just one idea. Im sure there are many other ways to fix this.
2016: Deans List Semi-Finalist/MAR Mount Olive District Engineering Inspiration Award/Buckeye Regional Second Alliance Captain/MAR Montgomery District Event Imagery Award/MAR Championship Gracious Professionalism Award
2015: MAR Mount Olive District Chairman's Award/MAR North Brunswick District Winners/MAR Championship Finalists
2014: MAR Clifton District Chairman's Award/MAR Championship Regional Chairman's Award
Unread 01-22-2016, 12:18 PM
Shu Shu is offline
FRC #2137 (TORC)
Yes, we have thought about this but I would like to keep the gearbox as low as possible for COG and packaging of other mechanisms.
Unread 01-22-2016, 12:20 PM
ThaddeusMaximus's Avatar
ThaddeusMaximus ThaddeusMaximus is offline
Thaddeus Hughes
FRC #4213 (MetalCow Robotics)
ThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the rough
If you want a visual aid.
Unread 01-22-2016, 12:33 PM
Shu Shu is offline
FRC #2137 (TORC)
Thanks, I think we could eliminate the third stage and get the additional gearing we need between the output shaft and wheel sprockets.
