Go to Post All the gangstas in FRC have solid gold CRios. It's called "blingage". If you don't have a solid gold CRio, you're not a straight-up G. :D - Jamie Kalb [more]
Unread 22-01-2016, 09:37
ProfessorAlekM ProfessorAlekM is offline
FRC #6190
ProfessorAlekM has a little shameless behaviour in the past
Communication between BeagleBone and RoboRIO
Hello!
Sorry if this has been covered on this forum before, but I can't figure out any way to connect my BeagleBone to the RoboRIO.
My goal is to have the BeagleBone and the RoboRIO exchanging strings of data (ie. coordinates). At first I looked into using i2c, then I heard there was UART, but I can't find any tutorials on how to use either of these interfaces. I need to find a communications interface that is supported by both the BeagleBone and the RoboRIO.
Thanks!
Unread 22-01-2016, 12:23
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Re: Communication between BeagleBone and RoboRIO
Try using UDP over ethernet. Implementing the UDP protocol on the RoboRio was fairly straightforward, and if you are using Java there are plenty of tutorials on how to do it (ie. https://docs.oracle.com/javase/tutor...ing/datagrams/). I actually have not worked on the beaglebone end of things, but I would imagine it is very similar.
Unread 23-01-2016, 17:50
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
UDP works great. We did it last year between Python on an rPi and the roboRIO running Java. Take a look at http://www.chiefdelphi.com/media/papers/3189, it points to our RoboRIO code.
We didn't get around to publishing the rPi end but I think the students grabbed it from a tutorial.
The nice thing we did was use JSON for a data format. That worked very very well.
Let me know if we can help!
