Go to Post "It's not a flashlight! it's an arduino with a really strong status LED!" - Leav [more]
Unread 22-01-2016, 11:03
rpaulsen rpaulsen is offline
Mr. Paulsen - Huguebots Coach 5202
AKA: Mr. Paulsen
FRC #5202 (The New Ro Bots)
rpaulsen is an unknown quantity at this point
Cheval de Fries Clamp Part/Vendor
Can anyone share which Vendor and part number they used for the pipe clamps on their Cheval De Fries? Apparently we ordered the wrong part the first time around, and need to find larger ones. Thanks.
Unread 22-01-2016, 11:23
bcampbell's Avatar
bcampbell bcampbell is offline
bcampbell will become famous soon enoughbcampbell will become famous soon enough
Re: Cheval de Fries Clamp Part/Vendor
We ordered this part from mcmaster. The fit was a little tight so we opened them up a little bit with an arbor press and had to use a small spacer so it sat flush with the wood. If we didn't open it on the arbor press a bit it wouldn't have a smooth motion.
http://www.mcmaster.com/#3039t17/=10sl5j9
Unread 22-01-2016, 11:25
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
This is the part number that was in one of the spreadsheets we have...
TE-16025 - McMaster-Carr 3039T18
We ended up getting the wrong ones from Lowes before I found the mcmaster PN, so we just modified the hole locations for the ones we bought
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 22-01-2016, 12:49
Arthur3103 Arthur3103 is offline
Mentor Team 3103
AKA: Arthur Purpich
FRC #3103 (Iron Plaid)
Arthur3103 is an unknown quantity at this point
We used brackets from Home Depot. We had to open them up a bit and we added washers between the bracket and the wood to allow for rotation room. It was a bit of trial and error getting the right number of washers (6) but the CdeF works.
Unread 22-01-2016, 14:53
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Same here on the HD clamps from the plumbing department. We also put a small amount of lithium grease on them as well.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 22-01-2016, 14:55
inorbert inorbert is offline
Build Captain and Driver
FRC #5811 (BONDS)
Team Role: Driver
Rookie Year: 2016
inorbert is an unknown quantity at this point
We drilled out wood and used that, while not perfect it is pretty good
Unread 22-01-2016, 18:30
allgoodthehood's Avatar
allgoodthehood allgoodthehood is offline
I just wanted to Clairafy
AKA: Claira Allgood
FRC #2512 (Duluth East Daredevils)
allgoodthehood will become famous soon enough
So what should we buy?
2016: (Northern Lights) Innovation in Control
2015: (Northern Lights) Team Spirit, Regional Finalists, and Regional Chairman's (Central Illinois) Regional Finalists and Innovation in Control (Hopper) Sub-Division Champs (Einstein) Finalists (Minnesota Sate) Champions (Minnie Mini) Champions
2014: (Northern Lights) Team Spirit (Gitchi Gummi Get Together) Finalists
Unread 22-01-2016, 20:17
Jalerre's Avatar
Jalerre Jalerre is offline
FRC #4965 (FIRE)
Jalerre is on a distinguished road
Cheval de "Fries"
Vex
2013: 415 - Fabrication, Programming, Electrical
2014: 415D - Captain, Programming Lead
FTC
2014: 7354 - Programming Lead
FRC
2013: 415 - Safety Animation, Fabrication
2014-2015: 4965 - Programming & Electrical
2016: 4965 - Captain, Programming Lead, Electrical
