Go to Post If Dave stops wearing the Hawaiian shirts, the terrorists have won. - kjohnson [more]
Unread 22-01-2016, 14:53
James Juncker's Avatar
James Juncker James Juncker is offline
Broken Robot Fixer
FRC #2834 (Bionic Black Hawks)
Team Role: Driver
James Juncker will become famous soon enough
If you are using some system I would recommend the use of a micro switch at the end of a lift should you go with that method to measure the time from start to stop. Similarly I would recommend to lift weight as the motors won't be used at their no load ability on a robot. I also think that some consideration ought to be given to building a gearbox to change motors in and out of and measuring their individual power consumed and difference in speed.
The FRC season has 3 steps
Eat
Build
Play
It is important to note that sleep is not included in these steps.
