Go to Post I like the gearboxes that can move my mechanical systems reliably. - Ginger Power [more]
Go Back   Chief Delphi > Technical > CAD
Unread 21-01-2016, 21:40
GCarnes's Avatar
GCarnes GCarnes is offline
FRC #5150 (Hybrid Hornets)
Team Role: Driver
GCarnes is just really niceGCarnes is just really niceGCarnes is just really niceGCarnes is just really nice
Chassis Testing in CAD
I was wondering if anyone could help me go about testing a CAD model of a robot on a CAD model of the field this year. Looking to test clearances and see if the robot would be able to cross over the different obstacles and then modify the robot model according to the test results. Any help or suggestions would be appreciated. Please specify for Inventor/Solidworks as I have both.
Unread 22-01-2016, 00:01
tab1a's Avatar
tab1a tab1a is offline
AKA: Tabia Schmidt
FRC #2521 (SERT)
tab1a has much to be proud oftab1a has much to be proud oftab1a has much to be proud oftab1a has much to be proud oftab1a has much to be proud oftab1a has much to be proud oftab1a has much to be proud oftab1a has much to be proud oftab1a has much to be proud oftab1a has much to be proud of
Re: Chassis Testing in CAD
You should check out BXD Synthesis for Autodesk: http://bxd.autodesk.com/
It's a program designed for Inventor used import CAD models of robots and drive them around a model of the field using their code. The beta was released pretty recently and I know our team is excited to try it out once we get a decent CAD model of our robot going. Good luck!
Unread 22-01-2016, 08:50
cgallagher's Avatar
cgallagher cgallagher is offline
Colleen Gallagher, SolidWorks Co-op
Rookie Year: 2016
cgallagher is an unknown quantity at this point
Check out using Gazebo for SolidWorks!
http://blogs.solidworks.com/teacher/...imulation.html
http://blogs.solidworks.com/teacher/...-to-Gazebo.pdf
-Colleen
Unread 22-01-2016, 13:57
xman206's Avatar
xman206 xman206 is offline
AKA: Xhelan Sylve
FRC #1983 (Skunk Works Robotics Team 1983)
Team Role: CAD
xman206 is an unknown quantity at this point
You could also just download the field model in CAD and import your CAD model of your robot in that.
Unread 22-01-2016, 14:45
ahartnet's Avatar
ahartnet ahartnet is online now
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant future
As someone brand new to CADing (using inventor) - what do you have to do so that CAD knows that something can't be passed through?
We've imported a lot of CAD models (from vex, field, and KOP) and assembled some drivetrain parts in CAD. We haven't put the robot on the field CAD yet - but from what I'm seeing so far, you could end up just shoving the robot through say the defense ramps - it won't know that that it can't go through it.
Completely rookie question I'm sure, but we're low on CAD experience. I'm happy we can modify and assemble parts together so far.
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
Unread 22-01-2016, 14:53
inorbert inorbert is offline
Build Captain and Driver
FRC #5811 (BONDS)
Team Role: Driver
Rookie Year: 2016
inorbert is an unknown quantity at this point
I am in the same boat, while not new to cad i dont know how to test relationships realistically
Unread 26-09-2016, 04:48
CoachDotKam CoachDotKam is offline
FRC #1189
CoachDotKam is an unknown quantity at this point
Not sure if this thread is still time relevant to anyone still. But at work we are developing a new web application for solid mechanics testing and feasibility of CAD models. Which could presumably allow for simulating the action of Bots interacting with field elements and such.
At this time we are preparing to launch our prototype to limited users as we work out the functionality and User Experience. http://vrify.esi-group.com/
would love to involve some teams in the early testing. The service would be free to use and will hopefully soon integrate consumer class Virtual Reality devices (cardboard and Samsung Gear more so than Vive or oculus).
Unread 12-10-2016, 14:14
Classicnerd1 Classicnerd1 is offline
AKA: Ethan Eaton
FRC #1764 (Liberty Robotics)
Team Role: CAD
Classicnerd1 is an unknown quantity at this point
There is a way in Inventor that you can make objects solid and that should help you fix the problem you are having
