Go to Post In FIRST, there's no such thing as too many 1/4-20 bolts, too many bottles of caffeinated beverage, and too much knowledge from others. - Billfred [more]
Unread 22-01-2016, 15:30
Andrew Duerner Andrew Duerner is offline
FRC #5818
Andrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud ofAndrew Duerner has much to be proud of
Re: 775pro encoders
Hi everyone,
Ether, here is a screen shot that we took at around 13 or 14 volts.
philso, I don't know if the spikes are from the scope or the encoder. I would have to borrow the scope again to play with more settings.
As for shooter wheel design, from my experiences in 2012, having the wheel be designed to mechanically impart enough energy into the ball can lead to a very accurate shot. Our encoder was used for ensuring that a very accurate rotational velocity was achieved so that the wheel would impart the same energy each time. We added closed loop PID control helped bring the wheel back up to speed in a short amount of time for the next shot. Which in 2012 was important as you could hold 3 balls. This year the cycle times will be much longer.
Name:	RS7 encoder at 13v.PNG
Andrew Duerner
Mechanical Engineer
Owner/Operator - www.armabot.com
Mentor FRC1717 2012-2013
Mentor FRC5818 2016
Armabot and FRC team involvement are unaffiliated.
Unread 22-01-2016, 18:53
Re: 775pro encoders
Yeah, looks to be spinning about 22000 rpm:
0.0009	seconds per cycle
3	cycles per rev
0.00270	seconds/rev
370.37	revs/sec
22,222	rpm
Unread 22-01-2016, 23:17
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: 775pro encoders
These certainly aren't the prettiest traces I've seen. However, given that these traces are directly on the motor, teams willing to invest a bit of time and a few cents on tiny capacitors will blow through these rough spots like they don't exist.
Unread 23-01-2016, 02:49
Stephen.Yanczura's Avatar
Stephen.Yanczura Stephen.Yanczura is offline
opportunist
FRC #0195 (Cyberknights)
Stephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to all
Re: 775pro encoders
We ordered a few of these and mechanically, they seem to be a very nice solution. Kudos on the design!
@Geetwo -
How would you utilize some baby capacitors to address the issues mentioned? What value and technology caps would I buy and how should I put them in the system? Thanks!
stephenyanczura
team 0195 | 2010-Pres. | cyberknights | Conn. | mentor
team 0195 | 2006-2007 | cyberknights | Conn. | mentor
team 1660 | 2005-2006 | harlemknights | NYC | mentor
team 0195 | 2001-2005 | cyberknights | Conn. | student
s.j.yanczura@gmail.com
Unread 23-01-2016, 11:42
Re: 775pro encoders
BTW, this also shows that there are 3 cycles per rev, aka:
- 3 rising edges per rev on each channel
- 6 edge transitions (rising+falling) per rev on each channel
- 12 edge transitions per rev in quadrature
