Go to Post There is a really bad trap most people fall into, when presented with data they tend to trust it. This is dangerous. - Andrew Schreiber [more]
Unread 22-01-2016, 16:49
SHARCRobotics SHARCRobotics is offline
FTC #4155
SHARCRobotics is an unknown quantity at this point
roboRIO connection issues
We have been trying to connect to our roboRIO via Ethernet but are unable to. Our team has already updated and reimaged the RIO. When we connect via USB cable we can find the RIO. We have also been able to ping the RIO when the Ethernet is connected however we still cant find the roboRIO when we look it up in Explorer. We are currently using Windows 8. Thanks and all help is much appreciated.
Unread 22-01-2016, 17:26
pluto7443 pluto7443 is offline
FRC #4917
pluto7443 is an unknown quantity at this point
Re: roboRIO connection issues
What IP address are you trying to connect to it with?
Unread 22-01-2016, 17:43
sam_who sam_who is offline
FRC #2190
sam_who is an unknown quantity at this point
If you connect both the USB and the ethernet cables, you should be able to use your browser to determine the ethernet IP address. Browse to address 172.22.11.2. This should take you to the roboRIO status page (via the USB cable). On this page you'll find the ethernet IP address. The address should have the form 10.TE.AM.xx. Use that address to reach the roboRIO over the ethernet cable.
On page 210 of the Getting Started with the 2016 Control System (pdf), you'll find an IP address to reach the roboRIO.
Unread 23-01-2016, 11:11
FTC #4155
We have connected to the roboRIO with both USB and Ethernet but only found an IP address starting with 169. We have also tries accessing that IP address directly on internet explorer without success. We haven't seen an address in the form of 10.TE.AM.xx.
Unread 23-01-2016, 20:09
A 169. address means the roboRIO isn't receiving DHCP from the Open Mesh radio.
Have you setup the radio using the FRC Radio Configuration Utility?
