Go to Post What no one knows is that I’m actually wearing fishnet stockings under this gown… as soon as they finish taking all of these darn photos I’m going to show Dave and Amanda who really has the best legs in FIRST!!! - MissInformation [more]
Unread 22-01-2016, 18:14
Spark Spark is offline
FRC #5931
Spark is an unknown quantity at this point
Narrow Spacer Widths
Whats the narrowest nylon spacer i can use between two moving parts without them rubbing?
Unread 22-01-2016, 18:26
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Narrow Spacer Widths
Is this a riddle?
I'd say as thin as you can slice it.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 22-01-2016, 18:30
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
http://www.mcmaster.com/#nylon-spacers/=10sqn64
http://www.mcmaster.com/#nylon-washers/=10sqnxl
http://www.angelbotics.com
Remember why you're doing this.
Unread 22-01-2016, 18:41
RoboChair's Avatar
AKA: Devin Castellucci
You can buy plastic shim washers from McMaster as thin as 0.001" thick. Teflon(PTFE) shim washers as thin as 0.005". You really don't need much between things unless the 2 parts are large and could deflect into each other, but that shouldn't be a problem if you design right.
You can also buy adhesive backed slick tape that is very thin and made of PTFE, UHMW, or PEEK. No cheap, but it's so easy to just slap some on to reduce friction in places.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 22-01-2016, 18:51
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
This question needs context.
Soft plastic will not last long on a drive train axle which has the wheels (gearboxes are probably fine though). It also will not last on axles which bear a lot of axial/side loads. The plastic will wear eventually.
I only bring this up because this is the reason our first regional in 2011 should have been GREAT, except for this exact problem on the drive train. We replaced the spacers with aluminum and our 2nd regional was our best ever up to that point in our history. Since your team is only signed up for one regional, you'll want to get this right .
GitHub
Unread 08-02-2016, 18:11
FRC #5931
belt to wheel distance
How close could a HTD 15mm belt get to the edge of a mecanum wheel without the screws on the mecanum wheel tearing through the belt? Would 0.1" be getting too close?
