roboRIO Image mismatch
I am trying to deploy code to my robot and I'm getting the message
BUILD FAILED C:\Users\Developer\wpilib\java\current\ant\build.xml:208: Assertion failed boolean test. roboRIO Image does not match plugin, allowed image version: 19 |
Re: roboRIO Image mismatch
Reinstalling tools by closing eclipse, deleting the [your user profile]/wpilib/ directory, then restarting eclipse and letting the plugin copy out the folder again fixed this issue for me.
You can also update the check manually in wpilib/cpp/current/ant/build.xml |
Okay so I figured out the issue: I had to update my National Instruments tools to this years version so that my roborRIO imaging tool had the correct image (v19). Thanks guys!!
After you reImage the roboRio you have to reinstall the Java JDK and JRE for this year. There is an option in Eclipse to do that.
