Go to Post A solution will present itself, all you have to do is be ready to take advantage of it when it does. - James1902 [more]
Unread 23-01-2016, 01:20
aniquedavla aniquedavla is offline
Head of Electronics and Programming
FRC #1266 (The Devil Duckies.)
Team Role: Electrical
aniquedavla is an unknown quantity at this point
Getting code that is on the crio back into a labview project?
I am not sure if this is as easy as it sounds,but is there a way we can access the code that has already been stored on the 4 slots crio's?
We lost our Labview codes for our 2014 robot, and we are having problems with our crio now. So i was wondering if there was a way i could get the code off the crio and back into a Labview Project or at least something close that would let me see how i programmed some things on there?
I am thinking its not possible because we already convert it into 'machine language' while building the code. I may be wrong? But would'nt it be as easy to convert it back to labview code?...idk?
Unread 23-01-2016, 08:40
Jalerre's Avatar
Jalerre Jalerre is offline
FRC #4965 (FIRE)
Jalerre is on a distinguished road
Re: Getting code that is on the crio back into a labview project?
It is not possible to get code from the Crio once it has been downloaded. When you download the code to the Crio, it is compiled (converted into machine language). It is not possible to "uncompile" (autocorrect wanted me to fix that word) a program. Think of it like this, there are many ways to do the same thing in software and the computer doesn't know which way it was done originally.
Vex
2013: 415 - Fabrication, Programming, Electrical
2014: 415D - Captain, Programming Lead
FTC
2014: 7354 - Programming Lead
FRC
2013: 415 - Safety Animation, Fabrication
2014-2015: 4965 - Programming & Electrical
2016: 4965 - Captain, Programming Lead, Electrical
