#31
Re: [Ri3D] Team Indiana Presents: Veronica
The 3D PDF is ready!
You will need to download it and open it IN ADOBE to view it properly. Check it out HERE -Team Indiana |
#32
I know the compression was >1", but I can't be positive on the exact amount (wasn't my subsystem). We did get the arc down to 29 degrees. The shooter also had strips of AM's abrasive green belting on the arc. Quote:
I can't be sure on the compression. It was at least 1" and had strips of abrasive material on the hood. |
#33
Hi PurpleINK,
THe PDF that was posted opens as a blank document with the SOLID WORKS statement at the bottom of the document. Do i need a special viewer for this PDF? Thanks |
#34
Are you opening it in your web browser, or with Adobe? You have to download it and open it with Adobe reader to be able to enable the 3D content.
#35
At the top of that page, you'll need to click the 'Download' button. It looks like an arrow pointing down towards a line. Once it has downloaded, simply open it. I hope this helps! |
